I am struggling for about 4 days to try to make the OTA work with my esp with 512k.
I am using a simple example that I find in the forum however it is not working properly, it always fail the upgrade.
The most strange part is that if I check the memory area in which the firmware user2.bin should be save the firmware is there, but the flag "upgrade_flag" nver changes.
Below is the code that I used:
#include <ets_sys.h>
#include <osapi.h>
#include "user_interface.h"
#include <os_type.h>
#include <gpio.h>
#include "driver/uart.h"
#include "mem.h"
#include <upgrade.h>
#include <ip_addr.h>
#include "espconn.h"
#define WIFI_CLIENTSSID "***********"
#define WIFI_CLIENTPASSWORD "***********"
extern int ets_uart_printf(const char *fmt, ...);
static struct ip_info ipConfig;
unsigned char *p = (unsigned char*)&ipConfig.ip.addr;
uint8 memory_map[128];
char i;
static void ICACHE_FLASH_ATTR ota_finished_callback(void *arg)
struct upgrade_server_info *update = arg;
ets_uart_printf("\n\n Upgradeflag 0x%02x ",update->upgrade_flag);
if (update->upgrade_flag == true)
ets_uart_printf("[OTA]success; rebooting!\n");
system_upgrade_reboot();
ets_uart_printf("[OTA]failed!\n");
spi_flash_read(0x41000,(uint32*)memory_map,128);
ets_uart_printf("----flag set----\n");
for(i=0;i<128;i++){
ets_uart_printf("0x%02x ",memory_map[i]);
ets_uart_printf("\n-------------------------------\n\n");
os_free(update->pespconn);
os_free(update->url);
os_free(update);
static void ICACHE_FLASH_ATTR handleUpgrade(uint8_t serverVersion, const char *server_ip, uint16_t port, const char *path)
const char* file;
uint8_t userBin = system_upgrade_userbin_check();
switch (userBin)
case UPGRADE_FW_BIN1: file = "user2.bin"; break;
case UPGRADE_FW_BIN2: file = "user1.bin"; break;
default: ets_uart_printf("[OTA]Invalid userbin number!\n");
return;
uint16_t version=1;
if (serverVersion <= version)
ets_uart_printf("[OTA]No update. Server version:%d, local version %d\n", serverVersion, version);
return;
ets_uart_printf("[OTA]Upgrade available version: %d\n", serverVersion);
struct upgrade_server_info* update = (struct upgrade_server_info *)os_zalloc(sizeof(struct upgrade_server_info));
update->pespconn = (struct espconn *)os_zalloc(sizeof(struct espconn));
os_memcpy(update->ip, server_ip, 4);
update->port = port;
ets_uart_printf("[OTA]Server "IPSTR":%d. Path: %s%s\n\n", IP2STR(update->ip), update->port, path, file);
update->check_cb = ota_finished_callback;
update->check_times = 10000;
update->url = (uint8 *)os_zalloc(512);
os_sprintf((char*)update->url,
"GET %s%s HTTP/1.0\r\n"
"Host: "IPSTR":%d\r\n"
"Connection: keep-alive\r\n Cache-Control: no-cache\r\n"
"\r\n",
path, file, IP2STR(update->ip), update->port);
ets_uart_printf("URL: %s.\r\n", (char*)update->url);
if (system_upgrade_start(update) == false)
ets_uart_printf("[OTA]Could not start upgrade\n");
os_free(update);
ets_uart_printf("[OTA]Upgrading...\n");
void ICACHE_FLASH_ATTR wifiConnectCb(System_Event_t *evt)
ets_uart_printf("Wifi event: %d\r\n", evt->event);
switch (evt->event) {
case EVENT_STAMODE_CONNECTED:
ets_uart_printf("connected to ssid %s, channel %d\n",
evt->event_info.connected.ssid,
evt->event_info.connected.channel);
break;
case EVENT_STAMODE_DISCONNECTED:
ets_uart_printf("disconnected from ssid %s, reason %d\n",
evt->event_info.disconnected.ssid,
evt->event_info.disconnected.reason);
break;
case EVENT_STAMODE_AUTHMODE_CHANGE:
ets_uart_printf("mode: %d -> %d\n",
evt->event_info.auth_change.old_mode,
evt->event_info.auth_change.new_mode);
break;
case EVENT_STAMODE_GOT_IP:
wifi_get_ip_info(STATION_IF, &ipConfig);
ets_uart_printf("%d.%d.%d.%d\n\n",p[0],p[1],p[2],p[3]);
char ipBuf[] = {192, 168, 0, 109};
handleUpgrade(2, ipBuf, 8000, "/");
break;
case EVENT_SOFTAPMODE_STACONNECTED:
ets_uart_printf("station: " MACSTR "join, AID = %d\n",
MAC2STR(evt->event_info.sta_connected.mac),
evt->event_info.sta_connected.aid);
break;
case EVENT_SOFTAPMODE_STADISCONNECTED:
ets_uart_printf("station: " MACSTR "leave, AID = %d\n",
MAC2STR(evt->event_info.sta_disconnected.mac),
evt->event_info.sta_disconnected.aid);
break;
default:
break;
void user_rf_pre_init(void)
uart_init(BIT_RATE_74880, BIT_RATE_74880);
void user_init(void)
struct station_config stconfig;
system_upgrade_init();
ets_uart_printf("SDK version:%s rom %d\n", system_get_sdk_version(), system_upgrade_userbin_check());
if(system_upgrade_userbin_check()==1){
ets_uart_printf("Boot Rom 1\n");
system_upgrade_flag_set(UPGRADE_FLAG_FINISH);
wifi_set_opmode(STATION_MODE);
if(wifi_station_get_config(&stconfig))
os_memcpy(&stconfig.ssid, WIFI_CLIENTSSID, sizeof(WIFI_CLIENTSSID));
os_memcpy(&stconfig.password, WIFI_CLIENTPASSWORD, sizeof(WIFI_CLIENTPASSWORD));
wifi_station_set_config(&stconfig);
ets_uart_printf("SSID: %s\n",stconfig.ssid);
spi_flash_read(0x72680,(uint32*)memory_map,128);
for(i=0;i<128;i++){
wifi_set_event_handler_cb(wifiConnectCb);
wifi_station_set_auto_connect(TRUE);
wifi_station_set_reconnect_policy(1);
wifi_station_connect();
I used the function "spi_flash_read" to check if the firmware is being written and before the upload and after a erase of the flash it read 0xff and after the function upgrade it reads the right value that it should have, I checked with a binary viewer to check if the last bytes were being written. However even if the firmware is right the callback function always return failed.
For the server side I used the code in:
https://gist.github.com/igrr/d35ab8446922179dc58c
Does anyone had a similar problem? Or might know the problem
Thank you very much,
Best Regards,
Leandro
