0,CLOSED
ERROR
Any ideas ?
I use last firmware, but firmware change give no result.
i try make a http://www.instructables.com/id/ESP8266 ... /?ALLSTEPS
Code in this instructable is little incorrect - see comments.
Explore... Chat... Share...
