Simply use the module as a very basic IP to serial bridge?
Posted: Fri Dec 05, 2014 3:42 pm
Hi everyone
I’m trying to figure out if there is an easy way to simply use the module as a very basic IP to serial bridge?
In other words I send a byte to its IP address (netcat type of script) and the byte comes out as serial on the TX pin or optimal for me would be the byte coming out of the pins as SPI?
Is such mode possible with the stock firmware and just configuring the module using standard AT commands? Could someone point me to the commands that would configure the module in such a mode?
Thank you
Thank you
