But , If I connect only 1 wire from ULN2003 or open NodeMCU before connect 4 wire , Then it can open webpage.
I want to use only 1 adapter . Current adapter is 2.5 A . How to fix it ?
Explore... Chat... Share...
xtal wrote:Is the voltage at esp 3.3 volts with relays connected, ?
Is the voltage adapter regulated or just a wall wart?
If yes to both questions , I would suspect electrical noise.
Try decouple relay driver with 47uf and .1uf cap....ensure good ground.....
