By helpme
#38727 The MQTT library provided in the SMING framework only supports String data type. However, I need to send binary data through MQTT. I managed to do that but there is a problem with my solution. Here is the relevant code;
Code: Select allMqttClient mqtt("192.168.1.71", 1883, onMessageReceived);
char buffer[100];
//buffer filled with binary data terminated with null character at this point
mqtt_msg = String(buffer);
String topic = "XXX";
mqtt.publish(topic, mqtt_msg );
I will terminate the binary data in buffer with a null character 0x00. The problem comes when 0x00 happened to be part of the binary data. How can this problem be solved?
By eduperez
#38743 Looks like that library is not ready to accept binary data, as it always uses NULL characters for termination. Perhaps you can reroute your project around that limitation: for example, you could use Base64 or some other algorithm to encode your binary data to ASCII. On the other hand, after a quick glimpse to the source code, it does not seem quite hard to modify that library to accept binary data.
By helpme
#38749
eduperez wrote:Looks like that library is not ready to accept binary data, as it always uses NULL characters for termination. Perhaps you can reroute your project around that limitation: for example, you could use Base64 or some other algorithm to encode your binary data to ASCII. On the other hand, after a quick glimpse to the source code, it does not seem quite hard to modify that library to accept binary data.
I tried to do just that. Modify the library to accept binary data.
The original code was;
Code: Select allbool MqttClient::publish(String topic, String message, bool retained /* = false*/)
   int res = mqtt_publish(&broker, topic.c_str(), message.c_str(), retained);
   return res > 0;
I added a new function to handle binary data.
Code: Select allbool MqttClient::publish_binary(String topic, const char* message, bool retained /* = false*/)
   int res = mqtt_publish(&broker, topic.c_str(), message, retained);
   return res > 0;
Unfortunately, this new function publish_binary takes in messages that are null-terminated like a normal string. What can be done to have a mqtt function that sends binary data? What is wrong with my code?
