I received a new ESP-01 and a FT232RL device to flash it with and have connected it all up as per the schematic below.
I first used ESP8266Flasher.exe and flashed the device successfully with NODEMCU firmware but then realised that I had lost AT commands so followed the guide below to attempt to flash "v0.9.5.2 AT Firmware.bin"
https://developer.mbed.org/users/sschocke/code/WiFiLamp/wiki/Updating-ESP8266-Firmware
The XTCOM_UTIL can connect to the device at 115200 baud and it takes 2/3 attempts to connect, but when I start the flashing procedure the progress bar gets stuck half way, it hangs around "Sent length: 234496 B / Total length: 520192 B" each time.
I thought I had completely bricked the device so I closed the program mid flash, and then tried to reconnect but there was no response, but after restarting the computer I can connect again, and start the flash again, but the same thing happens, it just get stucks half way through the flash.
Any ideas greatly appreciated,
Many thanks,
Nick
