Configure Module Using WIFI
Posted: Sat Jan 23, 2016 10:00 pm
Hi: I am a mobile guy and have used other WIFI modules. For most there is some sort of a configuration procedure that I can use the module without a MicroController or other means.
1) Module goes into AP Mode
2) Mobile Device can connect and configure to the existing AP with SSID / Password, etc.
3) Module reboots and Mobile device connects to new IP under the existing AP
With looking over this module...
0C-ESP8266__WROOM_WiFi_Module_Datasheet__EN_v0.4
One has to download the AT command firmware (this would be ok), but then end user has to configure using UART and not the WIFI.
Maybe there is a way to write / change the firmware to automatically go into AP mode and accept AT commands to reconfigure?
If this has been discussed before, my apologies, just starting to get into this module.
