Data not arriving on server.
Posted: Sun Jan 31, 2016 2:26 pm
Hello,
sorry if I am repeating an old thread, but I didn't find one with an answer that solved my issue.
I am using an ESP8266 + usbserial connected directly (without any resistor in the middle), as I saw in several tutorials at internet.
I refresh its firmware. I tried one from here, but after the refresh, it does not let me send any AT command (I am on MAC):
I am not sure if the line above is right, but it run without errors.
I found one tutorial in portuguese, with a link to one firmware:
http://www.mediafire.com/download/bn1wp ... Lua%29.rar
I refresh my ESP with the following command:
After that, I remove the pin from the ground and restart the usbserial (I did it previously every time that I wanted to get out of the update mode and go to the dev one).
I did:
I am having two issues, first of all, if I open from any machine in the network the following link:
http://192.168.25.70:3000/?device_id=1&flow=100&time=10
It registers on my node server what I want. From the AT+ command it does not register, meaning that it didn't arrive there. Why?
My second error is that after some time suddenly I start to receive the following message and after that I can't send any AT command anymore, so I need to refresh the firmware again
Thanks.
./esptool.py --port=/dev/cu.usbserial write_flash -fm=dio -fs=32m 0xfc000 at/esp_init_data_default.bin 0xfe000 at/blank.bin 0x00000 at/boot_v1.5.bin 0x01000 at/user1.1024.new.2.bin
./esptool.py --port=/dev/cu.usbserial write_flash -fm=dio -fs=32m 0x00000 v0.9.2.2\ AT\ Firmware.bin
I did:
AT+RST
OK
"Ê
.ÿ.M ;Ì;!Gú.Rl×..£
[System Ready, Vendor:www.ai-thinker.com]
AT+CWMODE=1
no change
AT+CWJAP="xxx","xxxx"
OK
AT+CIPSTART="TCP","192.168.25.70",3000
OK
Linked
AT+CIPSEND=74
> GET /?device_id=1&flow=100&time=10 HTTP/1.0\r\nHost: 192.168.25.70\r\n\r\n
SEND OK
OK
Unlink
Am1rþà;Ì;!Gú.Rl¡..£
Thanks.
