Things are starting to work! I just went to nodemcu-build.com and made a custom firmware. Among other things, my firmware was a dev build with http and ssl support. I have been able to hit my ssl endpoint and am expecting a response with a code of 200 and a value of 1.
My response is expecting JSON
Content-Type: application/jsonResponse handler.
function(code, data)
if (code < 0) then
print("HTTP request failed")
print(code, data)
The response is coming back with the proper status code of 200. The data seems to be coming back as the wrong type. I get a funky little gibberish character with a question mark in it. When I try to send content-type of text/plain, the return status is 415.
Can you please help me turn the gibberish character into a meaningful value?
Thanks
