- GPIO0 - pulled high with a 10k resistor and a push button to ground
GPIO2 - pulled high with a 10k resistor
EN - pulled high with a 10k resistor
RST - using a push button to ground
GPIO15 - ground with a 10k resistor
USB/TTL ground - to breadboard negative
GND - to breadboard negative
VCC - to 3.35v provided by a LM371 based circuit (up to 1A)
TX - to USB/TTL RX
RX - to USB/TTL TX
PORT OPEN 115200
Communication with MCU...
..Got answer! AutoDetect firmware...
Can't autodetect firmware, because proper answer not received.
lnn���bp��lrlrlp�n��lbn�|l�l��b��nn�I tried to push the reset button several times and then I received this output:
Fatal exception (0):
epc1=0x402012e8, epc2=0x00000000, epc3=0x00000000, excvaddr=0x00000000, depc=0x00000000
load 0x40100000, len 1396, room 16
tail 4
chksum 0x89
load 0x3ffe8000, len 776, room 4
tail 4
chksum 0xe8
load 0x3ffe8308, len 540, room 4
tail 8
chksum 0xc0
csum 0xc0
2nd boot version : 1.4(b1)
SPI Speed : 40MHz
SPI Mode : DIO
SPI Flash Size & Map: 8Mbit(512KB+512KB)
jump to run user1 @ 1000
�n't use rtc mem data
I can't receive any AT command answer...
I'm a bit lost now... could someone please give some help ?
thanks,
Chris
