SERVER
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
/* Set these to your desired credentials. */
const char *ssid = "SWITSH";
const char *password = "123456";
ESP8266WebServer server(80);
void handleRoot() {
server.send(200, "text/html", "<h1>You are connected</h1>");
delay(1000);
Serial.print("Configuring access point...");
/* You can remove the password parameter if you want the AP to be open. */
WiFi.softAP(ssid, password);
Serial.print("AP IP address: ");
Serial.println(myIP);
server.on("/", handleRoot);
server.begin();
server.handleClient();
}CLIENT:
const char* ssid = "SWITCH";
const char* password = "123456";
const char* host = "192.168.4.1";
delay(10);
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
delay(5000);
Serial.println(host);
WiFiClient client;
const int httpPort = 80;
return;
while(client.available()){
Serial.print(line);
