By f4u5t
#45317 I am attempting to read a 10 K ohm Type 3 Thermistor.
I have it wired up like this:
[Ground] ---- [10k-Resistor] -------|------- [Thermistor] ---- [+5v]
Analog Pin 0
I realize I need to reduce the voltage to 1Vdc max for the ESP8266
I do not understand how to size the resistor, can someone please help?
By trackerj
#45320
f4u5t wrote:I am attempting to read a 10 K ohm Type 3 Thermistor.
Analog Pin 0
It's a negative temperature coefficient one?
If you read my post about Internal ADC and Voltage Divider calculations you will find all the info that you need.
By trackerj
#45340 I really think you want to use this configuration:
[Vcc] ---- [Resistor Rdiv] -------|------- [Thermistor] ---- [GND]
[Analog Pin 0]
For Vcc = 5V (why 5V and not 3.3V?)
If is a NTC then (just example values, check NTC table for precise values for your specific Thermistor):
Rntc/25C = 10kohm
Rntc/125C = 300 ohm
- At 25C
ADC Input Voltage = 0.98 V -> Rdiv = 41k / Rntc =10k
- At 125C
ADC Input Voltage = 0.036 V <- Rdiv = 41k / Rntc =300
This will be your scale, from 0.036V to 0.98V.
To calculate Temperature, you can use table lookup technique or the Steinhart–Hart equation.
For more details read also : http://en.wikipedia.org/wiki/Thermistor
