By armin.kozljak
#45410 Hi,
Does anyone know how can I increase data transfer speed between two ESPs. I send data from one ESP (client) to other ESP (server). On client ESP I test voltage level (LOW or HIGH) on two digital input pins and I need to send this data to other ESP as fast as possible. With them code that I have now, data transfer is between 0.5 and 1 second. I use two ESP 12E.
CLIENT
const char* ssid     = "ateESPteam";
const char* password = "arminkozljak";
const char* host = "192.168.4.1";
const char* url = "";
String podatak;
bool stanje1,stanje2;
int GPIO12 = 12;
int GPIO4 = 4;
int pom;
  delay(10);
  Serial.println(ssid);
  WiFi.mode(WIFI_STA);
  WiFi.begin(ssid, password);
    Serial.print(".");
  Serial.println("");
  //pom = 0;
  stanje1 = digitalRead(GPIO4);
  delay(10);
  stanje2=digitalRead(GPIO12);
  delay(10);
  if((stanje1 == LOW)&&(stanje2 == LOW))
    podatak = "jedan";
  else if((stanje1 == LOW)&&(stanje2 == HIGH))
    podatak = "dva";
  else if((stanje1 == HIGH)&&(stanje2 == LOW))
    podatak = "tri";
  else if((stanje1 == HIGH)&&(stanje2 == HIGH))
    podatak = "cetiri";
    WiFiClient client;
  const int httpPort = 80;
  if (client.connect(host, httpPort)) {
    client.print(podatak);
  else{
        return;
SERVER
#include <WiFiClient.h>
/* Set these to your desired credentials. */
const char *ssid     = "ateESPteam";
const char *password = "arminkozljak";
int GPIO5 = 5;
int analog;
String line = "";
WiFiClient client;
WiFiServer server(80);
  pinMode(GPIO5, OUTPUT);
  analog = 0;
  delay(1000);
  Serial.print("Configuring access point...");
  /* You can remove the password parameter if you want the AP to be open. */
  WiFi.softAP(ssid, password);
  Serial.print("AP IP address: ");
  Serial.println(myIP);
  server.begin();
  Serial.println("server started");
void loop(){
  delay(10);
  if (!client)
      client = server.available();
     if (client.status() == CLOSED)
      client.stop();
    if (client.available() > 0)
      line = client.readStringUntil('\r');
      Serial.println(line);
      if ((analog < 1023) && (line == "dva")){
      analog = analog + 100;
      analogWrite(GPIO5 , analog);
        if (analog > 1000)
          analog = 1023;
      if ((analog > 1) && (line == "tri")){
      analog = analog - 100;
        if (analog  < 1)
          analog = 0;
      if (line == "GET /on HTTP/1.1"){
        digitalWrite(GPIO5 , HIGH);
        analog = 1023;}
      if (line == "GET /off HTTP/1.1"){
        digitalWrite(GPIO5 , LOW);
        analog = 0;
      line = "";
      client.stop();
