I can use SPI which is using too internal FLASH (SDCLK, SDD0 and SDD1). CS will be control by software, no hardware.
Just SPI initialize follows?
main code:
#define SPI 0
spi_init(SPI);
driver:
void ICACHE_FLASH_ATTR spi_init_gpio(uint8 spi_no, uint8 sysclk_as_spiclk){
// if(spi_no > 1) return; //Not required. Valid spi_no is checked with if/elif below.
uint32 clock_div_flag = 0;
if(sysclk_as_spiclk){
clock_div_flag = 0x0001;
if(spi_no==SPI){
WRITE_PERI_REG(PERIPHS_IO_MUX, 0x005|(clock_div_flag<<8)); //Set bit 8 if 80MHz sysclock required
PIN_FUNC_SELECT(PERIPHS_IO_MUX_SD_CLK_U, 1);
PIN_FUNC_SELECT(PERIPHS_IO_MUX_SD_CMD_U, 1);
PIN_FUNC_SELECT(PERIPHS_IO_MUX_SD_DATA0_U, 1);
PIN_FUNC_SELECT(PERIPHS_IO_MUX_SD_DATA1_U, 1);
}else if(spi_no==HSPI){
WRITE_PERI_REG(PERIPHS_IO_MUX, 0x105|(clock_div_flag<<9)); //Set bit 9 if 80MHz sysclock required
PIN_FUNC_SELECT(PERIPHS_IO_MUX_MTDI_U, 2); //GPIO12 is HSPI MISO pin (Master Data In)
PIN_FUNC_SELECT(PERIPHS_IO_MUX_MTCK_U, 2); //GPIO13 is HSPI MOSI pin (Master Data Out)
PIN_FUNC_SELECT(PERIPHS_IO_MUX_MTMS_U, 2); //GPIO14 is HSPI CLK pin (Clock)
//PIN_FUNC_SELECT(PERIPHS_IO_MUX_MTDO_U, 2); //GPIO15 is HSPI CS pin (Chip Select / Slave Select)
void ICACHE_FLASH_ATTR spi_init(uint8 spi_no){
if(!sSPI) vSemaphoreCreateBinary(sSPI);
spi_give_semaphore();
if(spi_no > 1) return; //Only SPI and HSPI are valid spi modules.
spi_init_gpio(spi_no, SPI_CLK_USE_DIV);
spi_clock(spi_no, SPI_CLK_PREDIV, SPI_CLK_CNTDIV);
spi_tx_byte_order(spi_no, SPI_BYTE_ORDER_HIGH_TO_LOW);
spi_rx_byte_order(spi_no, SPI_BYTE_ORDER_HIGH_TO_LOW);
SET_PERI_REG_MASK(SPI_USER(spi_no), SPI_CS_SETUP|SPI_CS_HOLD);
CLEAR_PERI_REG_MASK(SPI_USER(spi_no), SPI_FLASH_MODE);
Thanks, MG
