Explore... Chat... Share...
#include <SoftwareSerial.h>
SoftwareSerial mySerial(10, 11); // RX, TX
// Open serial communications and wait for port to open:
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
// set the data rate for the SoftwareSerial port
mySerial.begin(115200);
mySerial.println("Hello, world?");
void loop() { // run over and over
if (mySerial.available()) {
Serial.write(mySerial.read());
if (Serial.available()) {
mySerial.write(Serial.read());
}It takes about 20-25 seconds for home assistant c[…]
