I didn't find my answer anywhere so that's why I am posting my doubt here, If I'm duplication the thread then pardon me.
I am using ESP8266 ESP-12E. I have updated LED blinking code successfully using Arduino IDE 1.6.8. The sketch was working on ESP-12E board. Then I have tried ESP8266 WEBSERVER Example. I've uploaded the code successfully to ESP12E. After ESP12E reset i connect GPIO to VCC. I'm getting only garbage over terminal. Baud rate is 115200. I'm using LM1117 to power up ESP8266, and Using Prolific USB-RS232. ESP12E was working great with AT command with same power supply and USB-RS232 converter. I have connected GPIO0, RST and CH_PD to VCC with 10K pull UP.
I'm using this CODE:
* This sketch demonstrates how to set up a simple HTTP-like server.
* The server will set a GPIO pin depending on the request
* http://server_ip/gpio/0 will set the GPIO2 low,
* http://server_ip/gpio/1 will set the GPIO2 high
* server_ip is the IP address of the ESP8266 module, will be
* printed to Serial when the module is connected.
const char* ssid = "your_ssid";
const char* password = "your_password";
// Create an instance of the server
// specify the port to listen on as an argument
WiFiServer server(80);
delay(10);
// prepare GPIO2
pinMode(2, OUTPUT);
digitalWrite(2, 0);
// Connect to WiFi network
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
// Start the server
server.begin();
// Print the IP address
if (!client) {
return;
Serial.println("new client");
while(!client.available()){
delay(1);
Serial.println(req);
client.flush();
// Match the request
int val;
if (req.indexOf("/gpio/0") != -1)
val = 0;
else if (req.indexOf("/gpio/1") != -1)
val = 1;
else {
Serial.println("invalid request");
client.stop();
return;
// Set GPIO2 according to the request
digitalWrite(2, val);
client.flush();
// Prepare the response
String s = "HTTP/1.1 200 OK\r\nContent-Type: text/html\r\n\r\n<!DOCTYPE HTML>\r\n<html>\r\nGPIO is now ";
s += (val)?"high":"low";
s += "</html>\n";
// Send the response to the client
client.print(s);
delay(1);
Serial.println("Client disonnected");
// The client will actually be disconnected
// when the function returns and 'client' object is detroyed
