This is VB2015 code that works:
Public Function Encrypt(dataToEncrypt As String, password As String, salt As String) As String
' Generate a key and IV from the password and salt
Dim aesKeyMaterial As IBuffer
Dim iv As IBuffer
Dim iterationCount As UInteger = 10000
GenerateKeyMaterial(password, salt, iterationCount, aesKeyMaterial, iv)
Dim plainText As IBuffer = CryptographicBuffer.ConvertStringToBinary(dataToEncrypt, BinaryStringEncoding.Utf8)
' Setup an AES key, using AES in CBC mode and applying PKCS#7 padding on the input
Dim aesProvider As SymmetricKeyAlgorithmProvider = SymmetricKeyAlgorithmProvider.OpenAlgorithm(SymmetricAlgorithmNames.AesCbcPkcs7)
Dim aesKey As CryptographicKey = aesProvider.CreateSymmetricKey(aesKeyMaterial)
' Encrypt the data and convert it to a Base64 string
Dim encrypted As IBuffer = CryptographicEngine.Encrypt(aesKey, plainText, iv)
'IBuffer buffUTF8 = CryptographicBuffer.ConvertStringToBinary(strIn, BinaryStringEncoding.Utf8);
Return CryptographicBuffer.EncodeToBase64String(encrypted)
End Function
Public Function Decrypt(dataToDecrypt As String, password As String, salt As String) As String
Dim iv As IBuffer
' Convert the base64 input to an IBuffer for decryption
Dim ciphertext As IBuffer = CryptographicBuffer.DecodeFromBase64String(dataToDecrypt)
' Decrypt the data and convert it back to a string
Dim decrypted As IBuffer = CryptographicEngine.Decrypt(aesKey, ciphertext, iv)
Dim decryptedArray As Byte() = decrypted.ToArray()
Return Encoding.UTF8.GetString(decryptedArray, 0, decryptedArray.Length)
End Function
Private Sub GenerateKeyMaterial(password As String, salt As String, iterationCount As UInteger, ByRef keyMaterial As IBuffer, ByRef iv As IBuffer)
' Setup KDF parameters for the desired salt and iteration count
Dim saltBuffer As IBuffer = CryptographicBuffer.ConvertStringToBinary(salt, BinaryStringEncoding.Utf8)
Dim kdfParameters As KeyDerivationParameters = KeyDerivationParameters.BuildForPbkdf2(saltBuffer, iterationCount)
' Get a KDF provider for PBKDF2, and store the source password in a Cryptographic Key
Dim kdf As KeyDerivationAlgorithmProvider = KeyDerivationAlgorithmProvider.OpenAlgorithm(KeyDerivationAlgorithmNames.Pbkdf2Sha256)
Dim passwordBuffer As IBuffer = CryptographicBuffer.ConvertStringToBinary(password, BinaryStringEncoding.Utf8)
Dim passwordSourceKey As CryptographicKey = kdf.CreateKey(passwordBuffer)
' Generate key material from the source password, salt, and iteration count. Only call DeriveKeyMaterial once,
' since calling it twice will generate the same data for the key and IV.
Dim keySize As Integer = 128 / 8 '256 / 8
Dim ivSize As Integer = 128 / 8
Dim totalDataNeeded As UInteger = CUInt(keySize + ivSize)
Dim keyAndIv As IBuffer = CryptographicEngine.DeriveKeyMaterial(passwordSourceKey, kdfParameters, totalDataNeeded)
' Split the derived bytes into a seperate key and IV
Dim keyMaterialBytes As Byte() = keyAndIv.ToArray()
keyMaterial = WindowsRuntimeBuffer.Create(keyMaterialBytes, 0, keySize, keySize)
iv = WindowsRuntimeBuffer.Create(keyMaterialBytes, keySize, ivSize, ivSize)
End Sub
Usage:
Dim encryptString As String = Encrypt("my text", "mypassword", "mysalt")
Dim decryptString As String = Decrypt(encryptString, "mypassword", "mysalt")
And it works fine.
How can now I use this with ESP8266? I don't have any idea how to use crypto library. Let say that ESP and RaspberryPI will exchange keys at initial setup. What after that? I cannot make VB encrypt string and ESP crypto string the same...
Any suggestion?
