- Sun Apr 24, 2016 4:19 pm
#46105
The command you've sent is just enabling TCP server on port 80, it is not handling any HTTP requests, it is up to your application to do that. If you look at serial port, you should see the HTTP request been received, something like "+IPD,0,278:GET / HTTP/1.1….", but to display something in the browser, it will take some amount of effort/coding.
Personally, I would suggest you to go away from AT firmware, since it is simply too much overhead to build some simple stuff like a WebServer. You should go to some other framework, Arduino, Sming, of ESP-Httpd.
