By BruceFerjulian
#46362 Trying to get my head around writing to EEPROM.
I have defined a struct for my data but the first element in the struct is getting duplicated.
struct Test_Writing_EEPROM
char ItemNum01[32];
char ItemNum02[32];
char ItemNum03[32];
} StoredValues;
The first time I run the output of the first element is three (3) times longer than the last element.
What did we find currently stored in eeprom.
ItemNum01: 1XXXXXXXXXXXXXXXXXXXXXXXXXXXXXX23XXXXXXXXXXXXXXXXXXXXXXXXXXXXXX45XXXXXXXXXXXXXXXXXXXXXXXXXXXXXX6
SizeOF : 32
ItemNum02: 3XXXXXXXXXXXXXXXXXXXXXXXXXXXXXX45XXXXXXXXXXXXXXXXXXXXXXXXXXXXXX6
SizeOF : 32
ItemNum03: 5XXXXXXXXXXXXXXXXXXXXXXXXXXXXXX6
SizeOF : 32
BAD : We did not match ItemNum01.
What did we define to send to eeprom.
SizeOF : 32
SizeOF : 32
SizeOF : 32
The second time I restart and re-read the data, it looks the same.
Code: Select all#include <EEPROM.h>
int eepromAddress = 0;
  char ItemNum01[32];
  char ItemNum02[32];
  char ItemNum03[32];
} StoredValues;
  EEPROM.begin(512);
  EEPROM.get(eepromAddress, StoredValues);
  EEPROM.end();
  Serial.println("");
  Serial.println("What did we find currently stored in eeprom.");
  Serial.println("");
  Serial.print("ItemNum01: ");
  Serial.print(StoredValues.ItemNum01);
  Serial.println("");
  Serial.print("SizeOF   : ");
  Serial.print(sizeof(StoredValues.ItemNum01));
  Serial.println("");
  Serial.print("ItemNum02: ");
  Serial.print(StoredValues.ItemNum02);
  Serial.println("");
  Serial.print(sizeof(StoredValues.ItemNum02));
  Serial.println("");
  Serial.print("ItemNum03: ");
  Serial.print(StoredValues.ItemNum03);
  Serial.println("");
  Serial.print(sizeof(StoredValues.ItemNum03));
  if (StoredValues.ItemNum01 == "1XXXXXXXXXXXXXXXXXXXXXXXXXXXXXX2" )
    Serial.println("");
    Serial.println("");
    Serial.println("GOOD: We matched ItemNum01");
  } else {
    Serial.println("");
    Serial.println("");
    Serial.println("BAD : We did not match ItemNum01.");
    EEPROM.begin(512);
    strncpy(StoredValues.ItemNum01, "1XXXXXXXXXXXXXXXXXXXXXXXXXXXXXX2", 32);
    strncpy(StoredValues.ItemNum02, "3XXXXXXXXXXXXXXXXXXXXXXXXXXXXXX4", 32);
    strncpy(StoredValues.ItemNum03, "5XXXXXXXXXXXXXXXXXXXXXXXXXXXXXX6", 32);
    Serial.println("What did we define to send to eeprom.");
    EEPROM.put(eepromAddress, StoredValues);
    EEPROM.end();
  delay(5000);
By RichardS
#46363 How goes the .get() know your getting 96 bytes? Am I missing something?
RichardS
By RichardS
#46364 Also you did not leave any room for the 0 at the end of the string :-) If you want to put 32 things into a string, it needs to be char[33];
Or delete one X from each of the strings and all should be OK
RichardS
