By ankitmcgill
#46376 I need some help regarding FOTA on esp8266. I have my application running successfully on an esp8266-12e (including the code to connect to the upgrade server and download the new firmware when i send a particular command to the module).
What I am not sure about is how to generate user1.bin and user2.bin. I am using eclipse on windows and my compilation results in 2 files 0x00000.bin and 0x40000.bin.
The makefile I am using is
Code: Select all#############################################################
# Root Level Makefile
# Version 2.0
# (c) by CHERTS <sleuthhound@gmail.com>
BUILD_BASE   = build
FW_BASE      = firmware
# Base directory for the compiler
XTENSA_TOOLS_ROOT ?= c:/Espressif/xtensa-lx106-elf/bin
# base directory of the ESP8266 SDK package, absolute
SDK_BASE   ?= c:/Espressif/ESP8266_SDK
SDK_TOOLS   ?= c:/Espressif/utils
# esptool path and port
ESPTOOL ?= $(SDK_TOOLS)/esptool.exe
ESPPORT ?= COM3
# Baud rate for programmer
BAUD ?= 256000
# SPI_SPEED = 40, 26, 20, 80
SPI_SPEED ?= 40
# SPI_MODE: qio, qout, dio, dout
SPI_MODE ?= qio
# SPI_SIZE_MAP
# 0 : 512 KB (256 KB + 256 KB)
# 1 : 256 KB
# 2 : 1024 KB (512 KB + 512 KB)
# 3 : 2048 KB (512 KB + 512 KB)
# 4 : 4096 KB (512 KB + 512 KB)
# 5 : 2048 KB (1024 KB + 1024 KB)
# 6 : 4096 KB (1024 KB + 1024 KB)
SPI_SIZE_MAP ?= 0
ifeq ($(SPI_SPEED), 26.7)
    freqdiv = 1
    flashimageoptions = -ff 26m
    ifeq ($(SPI_SPEED), 20)
        freqdiv = 2
        flashimageoptions = -ff 20m
        ifeq ($(SPI_SPEED), 80)
            freqdiv = 15
            flashimageoptions = -ff 80m
            freqdiv = 0
            flashimageoptions = -ff 40m
        endif
    endif
endif
ifeq ($(SPI_MODE), QOUT)
    mode = 1
    flashimageoptions += -fm qout
    ifeq ($(SPI_MODE), DIO)
      mode = 2
      flashimageoptions += -fm dio
        ifeq ($(SPI_MODE), DOUT)
            mode = 3
            flashimageoptions += -fm dout
            mode = 0
            flashimageoptions += -fm qio
        endif
    endif
endif
ifeq ($(SPI_SIZE_MAP), 1)
  size_map = 1
  flash = 256
  flashimageoptions += -fs 2m
  ifeq ($(SPI_SIZE_MAP), 2)
    size_map = 2
    flash = 1024
    flashimageoptions += -fs 8m
    ifeq ($(SPI_SIZE_MAP), 3)
      size_map = 3
      flash = 2048
      flashimageoptions += -fs 16m
      ifeq ($(SPI_SIZE_MAP), 4)
      size_map = 4
      flash = 4096
      flashimageoptions += -fs 32m
        ifeq ($(SPI_SIZE_MAP), 5)
          size_map = 5
          flash = 2048
          ifeq ($(SPI_SIZE_MAP), 6)
            size_map = 6
            flash = 4096
            size_map = 0
            flash = 512
            flashimageoptions += -fs 4m
          endif
        endif
      endif
    endif
  endif
endif
# name for the target project
TARGET = app
# which modules (subdirectories) of the project to include in compiling
MODULES   = driver user
EXTRA_INCDIR = include $(SDK_BASE)/../extra/include
# libraries used in this project, mainly provided by the SDK
LIBS = c gcc hal phy pp net80211 lwip wpa main crypto smartconfig
# compiler flags using during compilation of source files
CFLAGS = -Os -g -O2 -std=gnu90 -Wpointer-arith -Wundef -Werror -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -mno-serialize-volatile -D__ets__ -DICACHE_FLASH
# linker flags used to generate the main object file
LDFLAGS = -nostdlib -Wl,--no-check-sections -u call_user_start -Wl,-static
# linker script used for the above linkier step
LD_SCRIPT = eagle.app.v6.ld
# various paths from the SDK used in this project
SDK_LIBDIR   = lib
SDK_LDDIR   = ld
SDK_INCDIR   = include include/json
# select which tools to use as compiler, librarian and linker
CC   := $(XTENSA_TOOLS_ROOT)/xtensa-lx106-elf-gcc
AR   := $(XTENSA_TOOLS_ROOT)/xtensa-lx106-elf-ar
LD   := $(XTENSA_TOOLS_ROOT)/xtensa-lx106-elf-gcc
OBJCOPY := $(XTENSA_TOOLS_ROOT)/xtensa-lx106-elf-objcopy
OBJDUMP := $(XTENSA_TOOLS_ROOT)/xtensa-lx106-elf-objdump
# no user configurable options below here
SRC_DIR      := $(MODULES)
BUILD_DIR   := $(addprefix $(BUILD_BASE)/,$(MODULES))
SDK_LIBDIR   := $(addprefix $(SDK_BASE)/,$(SDK_LIBDIR))
SDK_INCDIR   := $(addprefix -I$(SDK_BASE)/,$(SDK_INCDIR))
SRC         := $(foreach sdir,$(SRC_DIR),$(wildcard $(sdir)/*.c))
OBJ         := $(patsubst %.c,$(BUILD_BASE)/%.o,$(SRC))
LIBS      := $(addprefix -l,$(LIBS))
APP_AR      := $(addprefix $(BUILD_BASE)/,$(TARGET)_app.a)
TARGET_OUT   := $(addprefix $(BUILD_BASE)/,$(TARGET).out)
LD_SCRIPT   := $(addprefix -T$(SDK_BASE)/$(SDK_LDDIR)/,$(LD_SCRIPT))
INCDIR         := $(addprefix -I,$(SRC_DIR))
EXTRA_INCDIR   := $(addprefix -I,$(EXTRA_INCDIR))
MODULE_INCDIR   := $(addsuffix /include,$(INCDIR))
V ?= $(VERBOSE)
ifeq ("$(V)","1")
Q :=
vecho := @true
Q := @
vecho := @echo
endif
vpath %.c $(SRC_DIR)
define compile-objects
$1/%.o: %.c
   $(vecho) "CC $$<"
   $(Q) $(CC) $(INCDIR) $(MODULE_INCDIR) $(EXTRA_INCDIR) $(SDK_INCDIR) $(CFLAGS)  -c $$< -o $$@
endef
.PHONY: all checkdirs clean flash flashinit flashonefile rebuild
all: checkdirs $(TARGET_OUT)
$(TARGET_OUT): $(APP_AR)
   $(vecho) "LD $@"
   $(Q) $(LD) -L$(SDK_LIBDIR) $(LD_SCRIPT) $(LDFLAGS) -Wl,--start-group $(LIBS) $(APP_AR) -Wl,--end-group -o $@
   $(vecho) "------------------------------------------------------------------------------"
   $(vecho) "Section info:"
   $(Q) $(OBJDUMP) -h -j .data -j .rodata -j .bss -j .text -j .irom0.text $@
   $(Q) $(ESPTOOL) elf2image $(TARGET_OUT) -o$(FW_BASE)/ $(flashimageoptions)
   $(vecho) "Generate 0x00000.bin and 0x40000.bin successully in folder $(FW_BASE)."
   $(vecho) "0x00000.bin-------->0x00000"
   $(vecho) "0x40000.bin-------->0x40000"
   $(vecho) "Done"
$(APP_AR): $(OBJ)
   $(vecho) "AR $@"
   $(Q) $(AR) cru $@ $^
checkdirs: $(BUILD_DIR) $(FW_BASE)
$(BUILD_DIR):
   $(Q) mkdir -p $@
$(FW_BASE):
   $(Q) mkdir -p $@
flashonefile: all
   $(SDK_TOOLS)/gen_flashbin.exe $(FW_BASE)/0x00000.bin $(FW_BASE)/0x40000.bin 0x40000
   $(Q) mv eagle.app.flash.bin $(FW_BASE)/
   $(vecho) "Generate eagle.app.flash.bin successully in folder $(FW_BASE)."
   $(vecho) "eagle.app.flash.bin-------->0x00000"
   $(ESPTOOL) -p $(ESPPORT) -b $(BAUD) write_flash $(flashimageoptions) 0x00000 $(FW_BASE)/eagle.app.flash.bin
flash: all
   $(ESPTOOL) -p $(ESPPORT) -b $(BAUD) write_flash $(flashimageoptions) 0x00000 $(FW_BASE)/0x00000.bin 0x40000 $(FW_BASE)/0x40000.bin
# From http://bbs.espressif.com/viewtopic.php?f=10&t=305
# master-device-key.bin is only need if using espressive services
# master_device_key.bin 0x3e000 is not used , write blank
# See 2A-ESP8266__IOT_SDK_User_Manual__EN_v1.1.0.pdf
# http://bbs.espressif.com/download/file.php?id=532
# System parameter area is the last 16KB of flash
# 512KB flash - system parameter area starts from 0x7C000
#    download blank.bin to 0x7E000 as initialization.
# 1024KB flash - system parameter area starts from 0xFC000
#    download blank.bin to 0xFE000 as initialization.
# 2048KB flash - system parameter area starts from 0x1FC000
#    download blank.bin to 0x1FE000 as initialization.
# 4096KB flash - system parameter area starts from 0x3FC000
#    download blank.bin to 0x3FE000 as initialization.
# FLASH SIZE
flashinit:
   $(vecho) "Flash init data:"
   $(vecho) "Default config (Clear SDK settings):"
   $(vecho) "blank.bin-------->0x3e000"
   $(vecho) "blank.bin-------->0x3fc000"
   $(vecho) "esp_init_data_default.bin-------->0x3fc000"
   $(ESPTOOL) -p $(ESPPORT) write_flash $(flashimageoptions) \
      0x3e000 $(SDK_BASE)/bin/blank.bin \
      0x3fc000 $(SDK_BASE)/bin/esp_init_data_default.bin \
      0x3fe000 $(SDK_BASE)/bin/blank.bin
rebuild: clean all
clean:
   $(Q) rm -f $(APP_AR)
   $(Q) rm -f $(TARGET_OUT)
   $(Q) rm -rf $(BUILD_DIR)
   $(Q) rm -rf $(BUILD_BASE)
   $(Q) rm -rf $(FW_BASE)
$(foreach bdir,$(BUILD_DIR),$(eval $(call compile-objects,$(bdir))))
Can someone tell me what makefile do I need to use in order to generate user 1 and 2 bin files? If possible I would like to stick to my eclipse+windows environment rather than using linux
Thanks!
