my problem is as soon as i get the ready message on serial monitor, esp disconnects with a message "wifi disconnect", it starts again, ready and disconnects again.. i also cannot send any commands to esp thing because of it disconnecting i guess.
im using arduino uno to connect and an external power supply with lf33cv to regulate power..i just checked the voltage on the circuit and it is 3.18 volts(is it the problem?)
gpio2 is pulled high (with/without a resistor or floating, without ne difference)
vcc is connected to external power 3.3v
ch_pd is connected to vcc with a 0.5k resistor
rx, tx are connected to arduino uno without the atmega chip
reset is pulled high with a 0.5k resistor and a push button
gpio0 is pulled high with a resistor and a push button(floating or pulled high without resistor makes no diff)
ground of arduino, external psu and esp is connected
if it is of ne help, while it is disconnected i still see the aithinker in my available wireless network list
