This is ny first post so please forgive me for any infringements or lack of etiquette
I have been using Arduino IDE for the last year or so and has recently converted to ESP8266
I have been trying to write byte arrays to flash using PROGMEM and I am struggling
no matter how I word my issue I cannot find anything about this anywhere (so far)
I have been trying to make Poi and can convert gifs to arrays using python quite easily
I have found I can get them to work if I omit 'PROGMEM' but rapidly run out of RAM
I am using Arduino 1.6.8
NodeMCU v1.0 ESP8266 12-E
not using PROGMEM compiles fine and runs
Sketch uses 223,733 bytes (21%) of program storage space. Maximum is 1,044,464 bytes.
Global variables use 33,488 bytes (40%) of dynamic memory, leaving 48,432 bytes for local variables. Maximum is 81,920 bytes.
changing
const uint8_t pixels02[] = {
to const uint8_t pixels02[] PROGMEM = {
and
compiles fine
repeatedly resets
Sketch uses 223,737 bytes (21%) of program storage space. Maximum is 1,044,464 bytes.
Global variables use 31,220 bytes (38%) of dynamic memory, leaving 50,700 bytes for local variables. Maximum is 81,920 bytes.
only a 4 byte increase in used flash and a 2,268 byte decrease in ram
I have no idea what I am doing wrong
I have tried various combinations of including <pgmspace.h> and <Arduino.h> as seen on forums but to no avail
#include <Adafruit_DotStar.h>
#include <SPI.h>
//#include <Arduino.h>
//#include <pgmspace.h>
#define NUM_LEDS 36
#define DATAPIN 4
#define CLOCKPIN 5
Adafruit_DotStar strip = Adafruit_DotStar(
NUM_LEDS, DATAPIN, CLOCKPIN, DOTSTAR_BGR);
// flame1s.gif -------------------------------------------------------------
const uint8_t palette02[][3] PROGMEM = {
{ 0, 0, 0 },
{ 0, 0, 0 },
{ 1, 0, 0 },
// array cut down so as not to take up too much space on the forum
{ 54, 54, 14 },
{ 54, 54, 29 },
{ 54, 54, 54 } };
0X00, 0X00, 0X00, 0X00, 0X00, 0X00, 0X00, 0X00,
0X02, 0X16, 0X18, 0X10, 0X00, 0X00, 0X00, 0X00,
0X1E, 0X1E, 0X18, 0X1F, 0X17, 0X16, 0X18, 0X17,
0X18, 0X17, 0X1A, 0X18, 0X00, 0X18, 0X16, 0X17,
0X17, 0X18, 0X0B, 0X00, 0X11, 0X18, 0X16, 0X1A };
byte col;
byte r;
byte g;
byte b;
strip.begin();
strip.show();
//Pat2
for(int Pagea = 0; Pagea < sizeof(pixels02); Pagea = Pagea + NUM_LEDS)
for(byte Strip = 0; Strip < NUM_LEDS; Strip++)
col = pixels02[Pagea + Strip];
r = palette02[col] [0];
g = palette02[col] [1];
b = palette02[col] [2];
strip.setPixelColor(Strip, r, g, b);
strip.show();
yield();
