By nikant
#41138 Hi to all! (and a thanks to this community, I've learned a lot reading here and still learning)
I wonder if it possible to use the ESP as server and client simultaneously for example a GET request.
(I'm using a ESP-12E on devkit1)
What I need is while working as a server and responding to requests to GET a page every i.e. 1 hour
the working code of a server is (generic)
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
/* Set these to your desired credentials. */
const char *ssid = "XXXXXXXX";
const char *password = "XXXXXXXXXXXXXXXXXX";
// Update these with values suitable for your network.
IPAddress ip(192, 168, 1, 10); //Node static IP
IPAddress gateway(192, 168, 1, 1);
ESP8266WebServer server(80);
  delay(1000);
  Serial.begin(9600);
  WiFi.mode(WIFI_STA);
  WiFi.config(ip, gateway, subnet);
  WiFi.begin(ssid, password);
  Serial.println("");
  Serial.println("done");
  Serial.println("");
  Serial.println(ssid);
  Serial.print("IP address: ");
  server.on("/", []() {
    delay(5000);
    server.send(200, "text/html", webPage1 + pinstate + webPage2);
  server.begin();
  server.handleClient();
and it's OK, works as it should..
now the following code is obviously WRONG (while delaying in the loop section the server doesn't respond)
const char *host = "www.example.com";
  delay(1000);
  Serial.begin(9600);
  Serial.println("");
  Serial.println("");
    delay(5000);
  server.begin();
  WiFiClient client;
  const int httpPort = 80;
    return;
  // We now create a URI for the request
  String url = "/";
  Serial.print("Requesting URL: ");
  Serial.println(url);
  client.print(String("GET ") + url + " HTTP/1.1\r\n" +
               "Host: " + host + "\r\n" +
               "Connection: close\r\n\r\n");
  delay(10);
  client.flush();
  client.stop();
  delay(3600000);
is what I'm seeking doable?
