By batuhanfaik
#39220 Hello everyone! I own a NodeMCU v1.0 board with 0.9.6 LUA and an Arduino Due R3 board. I would like to control my Arduino Due board with NodeMCU over the internet. (Cloudly from anywhere) I want to be able to send commands/programs to my Arduino board and log sensors (Temperature, humidity, gas etc.) that are either connected to the Arduino or the NodeMCU, whichever works. I want to be able to control servos, LEDs etc, and log sensors at the same time. I also want the board to take action depending on the data coming from the sensors. (For example if the temprature is over 25 degrees Celcius, send me an e-mail etc.) This is not that necessary but other functions are important. Are these things possible to with NodeMCU and an Arduino Due? Should I buy an Arduino Yun or an XBee to control Arduino Due? What is the best and cheapest solution for me to this project? (I don't know LUA well, but I know C, C# pretty good) Thanks for your help in advance! :)
By Mmiscool
#39221 You can certainly use the esp in conjunction with another microcontroller but why?
The esp8266 has a fully functional arduino environment. You can program it just like an arduino. Email, sensors and many other things will work right out the gate.
By batuhanfaik
#39224
Mmiscool wrote:You can certainly use the esp in conjunction with another microcontroller but why?
Thank you for the quick reply but I have no idea how to. Is there any sources that I can learn how to control servos, sensors, LEDs, Arduino's etc. with ESP? (I don't really wanna go buy another ESP, I know that NodeMCU can do everything that other ESPs do.)
By Mmiscool
#39235 The esp8266 can be used like an arduino. No need to have a secondary microcontroller.
If you go to
https://github.com/esp8266/Arduino
It has some information about how to get set up.
Also you can watch this YouTube video.
https://youtu.be/zMR0-qUUN0w
You might also check out the arduino section of the forum here.
viewforum.php?f=25
