By viamar
#58661 @ martinayotte
Pleas can you help me why I cant't use fromString? I have this error:
Code: Select allString ipaddr="192.168.1.63";
IPAddress ip;
ip.fromString(ipaddr.c_str());
Code: Select allerror: 'ip' does not name a type
exit status 1
[Finished in 19.2s with exit code 1]
This code in the same program compiles correctly
Code: Select allIPAddress timeServer1(193, 204, 114, 232);
String ipAsString = timeServer1.toString();
Thanks
By viamar
#58682 Thanks for the prompt answer, but the ESP package is the latest 2.3.0.
I've isolated the problem and is a scope issue, but I don't understand the reason.
This code works:
IPAddress ip;
  Serial.println(ip);
  Serial.println(ipAsString);
 delay(100);
And this gives error "'ip' does not name a type"
IPAddress ip;
  Serial.println(ip);
 delay(100);
I need "ip" and "ipAsString" as global for this reason I put them outside.
