Re: Can't connect Arduino Uno to ESP8266
Posted:
Thu Dec 04, 2014 9:00 pm
by nodduino
frasenci wrote:Do not discard the "faulty" one ESP.
Just try again powering from an robust 3.3 V source.
Greetings
Francisco
Thank you for the suggestion. I'll give it a try when I receive the voltage regulator.
Posted:
Sat Dec 13, 2014 10:17 am
by boff
Hi,
I had a module which showed all the symptoms that you describe, ie continuous blue light and garbage from the Tx pin.
In desperation I tried to re-flash it and this was successful. I have had no problems since then.
The new firmware also allows me to change the baud rate which is very useful.
http://blog.electrodragon.com/cloud-upd ... p8266-now/
Posted:
Mon Feb 23, 2015 3:45 am
by Kapil Rathi
I used esp8266 with cp2102 with RC/TX and TX/RX, VCC & CH_PD -> 3.3v (from LD33v), GND-0v. As soon as I open Serial monitor, it shows never ending garbage data untill I close that. I change the baud rate also but no change. What should I do in that case?
Thanks
Kapil
Posted:
Mon Feb 23, 2015 11:22 am
by raz123
Tomer wrote:the ESP module requires 300ma+
Do you have some empiric evidence to back this claim?
Mine works perfectly when powered from the 3.3v pin.
