I am having issues with the audio transfer.
Everytime that I run my sketch, I receive a different combination of characters that does not match the original file. I thought it could be the serial buffer overflow but I don´t think that is the problem because I can transfer .TXT files with no problem.
Do you guys have any thoughts of what can be happening? There is any way that I can check if each character received match the original?
The code is bellow:
#include <FirebaseArduino.h>
// I only use Firebase to get the URL
#define FIREBASE_HOST "***.firebaseio.com"
#define FIREBASE_AUTH "****"
#define WIFI_SSID "**"
#define WIFI_PASSWORD "***"
const char* host = "textfiles.com"; //"cyanu.com";
String URL;
WiFiClient client;
// connect to wifi.
WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
Serial.print("connecting");
Serial.print(".");
Serial.print("connected: ");
// CONNECT TO FIREBASE
Firebase.begin(FIREBASE_HOST, FIREBASE_AUTH);
delay(1000);
//RETRIEVE URL
Serial.println("URL: ");
URL = Firebase.getString("/mensagem/url");
Serial.println(URL);
delay(1000);
// CONNECT TO CYANU FOR DOWNLOADING
Serial.println(host);
const int httpPort = 80;
return;
}else{Serial.println("Connection Succeeded");}
// REQUEST DOWNLOAD OF THE FILE
client.print(String("GET ") + URL +" HTTP/1.1\r\n" +
"Host: " + host + "\r\n" +
"Connection: close\r\n\r\n");
unsigned long timeout = millis();
while (client.available() == 0) {
if (millis() - timeout > 5000) {
Serial.println(">>> Client Timeout !");
client.stop();
return;
Serial.println('+');
String line;
while(client.connected()){
line = client.readStringUntil('\r');
Serial.print(line);
Serial.println("");
Serial.println("");
int n = 0;
}And here is the DUE code
#include <SPI.h>
#include <Adafruit_VS1053.h>
#include <SD.h>
#include <SdFat.h>
#include <SdFatUtil.h>
// SD CARD DEFINITIONS //
#define CARDCS 4 // Card chip select pin
#define SHIELD_RESET -1 // VS1053 reset pin (unused!)
#define SHIELD_CS 7 // VS1053 chip select pin (output)
#define SHIELD_DCS 6 // VS1053 Data/command select pin (output)
#define DREQ 3 // VS1053 Data request, ideally an Interrupt pin
Adafruit_VS1053_FilePlayer musicPlayer = Adafruit_VS1053_FilePlayer(SHIELD_RESET, SHIELD_CS, SHIELD_DCS, DREQ, CARDCS);
File fh;
File root;
char filename[15];
unsigned long timeOUT;
void setup()
Serial3.begin(115200);
Serial.println("iniciou");
initializeSD();
timeOUT = millis()+ 10000;
bool Write;
bool runn = true;
void loop()
while(runn)
if(Serial3.available())
timeOUT = millis()+ 6000;
char rx = Serial3.read();
Serial.print(rx);
fh.print(rx);
}else{
if(millis() > timeOUT){
fh.close();
Serial.println("file is closed");
runn = false;
break;
void initializeSD()
if (! musicPlayer.begin()) { // initialise the music player
Serial.println(F("Couldn't find VS1053, do you have the right pins defined?"));
while (1);
Serial.println(F("VS1053 found"));
if(!SD.begin(CARDCS)){
Serial.println("SD initialization failed!");
return;
Serial.println("initialization done.");
root = SD.open("/");
strcpy(filename, "RECORD00.txt");
for (uint8_t i = 0; i < 100; i++) {
filename[6] = '0' + i/10;
filename[7] = '0' + i%10;
if (! SD.exists(filename)) {
break;
fh = SD.open(filename, FILE_WRITE);
if(!fh)
Serial.println(F("SD file oppening fail"));
printDirectory(root, 0);
// errorLoop prints an error code, then loops forever.
void errorLoop(int error)
Serial.print(F("Error: ")); Serial.println(error);
Serial.println(F("Looping forever."));
for (;;)
// serialTrigger prints a message, then waits for something
// to come in from the serial port.
void serialTrigger(String message)
Serial.println(message);
while (!Serial.available());
while (Serial.available())
Serial.read();
void printDirectory(File dir, int numTabs) {
while (true) {
File entry = dir.openNextFile();
if (! entry) {
// no more files
Serial.println("no more files");
break;
for (uint8_t i = 0; i < numTabs; i++) {
Serial.print('\t');
Serial.print(entry.name());
if (entry.isDirectory()) {
Serial.println("/");
printDirectory(entry, numTabs + 1);
} else {
// files have sizes, directories do not
Serial.print("\t\t");
Serial.println(entry.size(), DEC);
entry.close();
Thanks for the help!
