I did find a code on github https://github.com/l740416/ESP8266-WifiSniffer/blob/master/ESP8266-Arduino-WifiSniffer.ino to see mac addresses and I am trying to save it on a SD card but the Arduino compiler says it ambiguous!
Using library SPI at version 1.0 in folder: C:\Users\Ali\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SPI
Using library SD at version 1.0.5 in folder: C:\Users\Ali\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SD
Using library ESP8266WiFi at version 1.0 in folder: C:\Users\Ali\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi
exit status 1
call of overloaded 'println(uint8 [36])' is ambiguous
Can Anyone help me to understand it why and help me out?
// Adapted from kissste's code and fix bugs
#include <SPI.h>
#include <SD.h>
#include "ESP8266WiFi.h"
extern "C" {
#include "c_types.h"
#include "ets_sys.h"
#include "os_type.h"
#include "osapi.h"
#include "mem.h"
#include "user_interface.h"
#include "smartconfig.h"
#include "lwip/opt.h"
#include "lwip/err.h"
#include "lwip/dns.h"
#include "user_config.h"
#define user_procTaskPrio 0
#define user_procTaskQueueLen 1
#define CHANNEL_HOP_INTERVAL 5000
const int chipSelect = 4;
//os_event_t user_procTaskQueue[user_procTaskQueueLen];
static os_timer_t channelHop_timer;
//static void loop(os_event_t *events);
static void promisc_cb(uint8 *buf, uint16 len);
struct RxControl {
signed rssi:8;
unsigned rate:4;
unsigned is_group:1;
unsigned:1;
unsigned sig_mode:2;
unsigned legacy_length:12;
unsigned damatch0:1;
unsigned damatch1:1;
unsigned bssidmatch0:1;
unsigned bssidmatch1:1;
unsigned MCS:7;
unsigned CWB:1;
unsigned HT_length:16;
unsigned Smoothing:1;
unsigned Not_Sounding:1;
unsigned:1;
unsigned Aggregation:1;
unsigned STBC:2;
unsigned FEC_CODING:1;
unsigned SGI:1;
unsigned rxend_state:8;
unsigned ampdu_cnt:8;
unsigned channel:4;
unsigned:12;
struct sniffer_buf {
struct RxControl rx_ctrl;
uint8 buf[36 ]; // head of ieee80211 packet
#define printmac(buf, i) Serial.print(buf[i+0],HEX); Serial.print(":"); Serial.print(buf[i+1],HEX); Serial.print(":"); Serial.print(buf[i+2],HEX); Serial.print(":"); Serial.print(buf[i+3],HEX); Serial.print(":"); Serial.print(":"); Serial.print(buf[i+4],HEX); Serial.print(":"); Serial.print(buf[i+5],HEX);
void channelHop(void *arg)
// 1 - 13 channel hopping
uint8 new_channel = wifi_get_channel() % 12 + 1;
Serial.print("** hop to ");
Serial.println(new_channel);
wifi_set_channel(new_channel);
static void ICACHE_FLASH_ATTR
File dataFile = SD.open("datalog.txt", FILE_WRITE);
struct sniffer_buf *sniffer = (struct sniffer_buf*) buf;
Serial.print(sniffer->rx_ctrl.rssi,DEC);
Serial.print(" :: ");
printmac(sniffer->buf, 10); //source mac
dataFile.println(sniffer->buf, 10);
Serial.print(" -> ");
printmac(sniffer->buf, 4); //destination mac
Serial.println("");
dataFile.close();
//Init function
void setup ()
delayMicroseconds(100);
Serial.println("*** Monitor mode test ***");
Serial.print("Initializing SD card...");
// see if the card is present and can be initialized:
if (!SD.begin(chipSelect)) {
Serial.println("Card failed, or not present");
// don't do anything more:
return;
Serial.println("card initialized.");
Serial.print(" -> Promisc mode setup ... ");
wifi_set_promiscuous_rx_cb(promisc_cb);
wifi_promiscuous_enable(1);
Serial.println("done.");
Serial.print(" -> Timer setup ... ");
os_timer_disarm(&channelHop_timer);
os_timer_setfn(&channelHop_timer, (os_timer_func_t *) channelHop, NULL);
os_timer_arm(&channelHop_timer, CHANNEL_HOP_INTERVAL, 1);
Serial.println("done.\n");
Serial.print(" -> Set opmode ... ");
wifi_set_opmode( 0x1 );
//Start os task
//system_os_task(loop, user_procTaskPrio,user_procTaskQueue, user_procTaskQueueLen);
Serial.println(" -> Init finished!");
delay(10);
