Data received by the POST method :
if (server.hasArg("SSID") && server.hasArg("SENHA")&& server.hasArg("IPESTACAO")){//enviou configurações
String _qip = server.arg("IPESTACAO");
IPAddress qip=ipFromString(_qip.c_str());Explore... Chat... Share...
IPAddress qip=ipFromString(_qip.c_str());IPAddress ipFromString(const char *address) {
// TODO: add support for "a", "a.b", "a.b.c" formats
IPAddress _IP;
uint16_t acc = 0; // Accumulator
uint8_t dots = 0;
while (*address)
char c = *address++;
if (c >= '0' && c <= '9')
acc = acc * 10 + (c - '0');
//acc = uint8_t(acc);
if (acc > 255) {
// Value out of [0..255] range
//return false;
_IP = IPAddress(0,0,0,0);
return _IP;
else if (c == '.')
if (dots == 3) {
// Too much dots (there must be 3 dots)
//return false;
return _IP;
_IP[dots++] = acc;
acc = 0;
// Invalid char
//return false;
return _IP;
if (dots != 3) {
// Too few dots (there must be 3 dots)
//return false;
return _IP;
_IP[3] = acc;
return _IP;
}It takes about 20-25 seconds for home assistant c[…]
