ets Jan 8 2013,rst cause:2, boot mode:(1,6)
ets Jan 8 2013,rst cause:4, boot mode:(1,6)
wdt reset
here is a link to the code on github
https://github.com/drifterz28/kegbot/bl ... kegbot.ino
thanks.
Explore... Chat... Share...
wdt reset
drifterz28 wrote:I am working on using some weight sensors and building some scales. I have everything setup and work / runs on the ESP but as soon as I try to get WIFI involved the sketch fails before the setup and just gives me thisCode: Select allets Jan 8 2013,rst cause:2, boot mode:(1,6)
wdt reset
HX711 hx711_1(1, 0); hx711_1.begin(1, 0);
