I'm using ESP-12F AT Command Firmware and programming using Arduino IDE
the code of server :
// Membuat Variabel Autentikasi
const char* ssid = "master-sport";
const char* password = "1234567890";
// Mengatur IP Address
IPAddress CLIENTA(192,168,4,100);
// Create an instance of the server
// specify the port to listen on as an argument
WiFiServer server(80);
WiFiClient client;
delay(10);
// Mengatur WiFi ----------------------------------------------------------
Serial.print("Configuring access point...");
WiFi.mode(WIFI_AP);
WiFi.softAP(ssid, password);
// Start the server -------------------------------------------------------
server.begin();
Serial.println("Server dijalankan");
// Print the IP address ---------------------------------------------------
// Check if a client has connected ----------------------------------------
client = server.available();
if (!client) {
return;
// Wait until the client sends some data ----------------------------------
Serial.println("new client");
while(!client.available()){
delay(1);
// Read the first line of the request -------------------------------------
Serial.println(req);
client.flush();
// Match the request ------------------------------------------------------
const char* host;
int val;
if (req.indexOf("/sr/0") != -1){
host = "sa";
val = 0;
else if (req.indexOf("/sr/1") != -1){
host = "sa";
val = 1;
else {
Serial.println("invalid request");
client.stop();
return;
client.flush();
Serial.println("Client disonnected");
// Pengiriman data ke client -----------------------------------------------
int value = 0;
delay(5000);
++value;
Serial.println(CLIENTA);
// Memebuat TCP Connection Menggunakan WiFiClient --------------------------
const int httpPort = 80;
if (!client.connect(CLIENTA, httpPort)) {
return;
// Membuat URL untuk dikirimkan -------------------------------------------
String url = host;
url += "/";
url += val;
Serial.println(url);
// Mengirimkan Request ke Client ------------------------------------------
"Host: " + CLIENTA + "\r\n" +
"Connection: close\r\n\r\n");
unsigned long timeout = millis();
while (client.available() == 0) {
if (millis() - timeout > 5000) {
Serial.println(">>> Client Timeout !");
client.stop();
return;
// Melihat semua line balasan dari server dan menampilkan di Serial -------
while(client.available()){
Serial.print(line);
//=============================================================================Client code :
#include <Adafruit_NeoPixel.h>
#ifdef __AVR__
#include <avr/power.h>
#endif
#define PIN 13
IPAddress IP(192,168,4,100);
IPAddress NETMASK(255,255,255,0);
IPAddress NETWORK(192,168,4,1);
// Menasukan LED RGB
Adafruit_NeoPixel strip = Adafruit_NeoPixel(60, PIN, NEO_GRB + NEO_KHZ800);
delay(10);
// Connect to WiFi network ------------------------------------------------
Serial.println(ssid);
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);
WiFi.config(IP, NETMASK, NETWORK);
Serial.print(".");
Serial.println("");
server.begin();
// Menjalankan LED RGB ----------------------------------------------------
strip.begin();
strip.show();
if (!client) {
return;
delay(1);
client.flush();
int val;
if (req.indexOf("/sa/0") != -1){
strip.setPixelColor(4,0x000000); //LED menjadi mati -------------------
strip.show();
else if (req.indexOf("/sa/1") != -1){
strip.setPixelColor(4, 0xFF0000); //LED menjadi merah -----------------
strip.show();
else {
client.stop();
return;
client.flush();
//============================================================================whats wrong that code ?
