ESP8266 to ESP8266 Client Server Connection can't Connect
Posted: Wed Nov 23, 2016 12:27 pm
I have a project to connecting dual esp8266 using client server method, my expectation the server can get command from user from web request, and the request will be forward to client from server to turn on led. But the connection from server always failed
I'm using ESP-12F AT Command Firmware and programming using Arduino IDE
the code of server :
Client code :
whats wrong that code ?
// Membuat Variabel Autentikasi
const char* ssid = "master-sport";
const char* password = "1234567890";
// Mengatur IP Address
IPAddress CLIENTA(192,168,4,100);
// Create an instance of the server
// specify the port to listen on as an argument
WiFiServer server(80);
WiFiClient client;
delay(10);
// Mengatur WiFi ----------------------------------------------------------
Serial.print("Configuring access point...");
WiFi.mode(WIFI_AP);
WiFi.softAP(ssid, password);
// Start the server -------------------------------------------------------
server.begin();
Serial.println("Server dijalankan");
// Print the IP address ---------------------------------------------------
// Check if a client has connected ----------------------------------------
client = server.available();
if (!client) {
return;
// Wait until the client sends some data ----------------------------------
Serial.println("new client");
while(!client.available()){
delay(1);
// Read the first line of the request -------------------------------------
Serial.println(req);
client.flush();
// Match the request ------------------------------------------------------
const char* host;
int val;
if (req.indexOf("/sr/0") != -1){
host = "sa";
val = 0;
else if (req.indexOf("/sr/1") != -1){
host = "sa";
val = 1;
else {
Serial.println("invalid request");
client.stop();
return;
client.flush();
Serial.println("Client disonnected");
// Pengiriman data ke client -----------------------------------------------
int value = 0;
delay(5000);
++value;
Serial.println(CLIENTA);
// Memebuat TCP Connection Menggunakan WiFiClient --------------------------
const int httpPort = 80;
if (!client.connect(CLIENTA, httpPort)) {
return;
// Membuat URL untuk dikirimkan -------------------------------------------
String url = host;
url += "/";
url += val;
Serial.print("Requesting URL: ");
Serial.println(url);
// Mengirimkan Request ke Client ------------------------------------------
client.print(String("GET ") + url + " HTTP/1.1\r\n" +
"Host: " + CLIENTA + "\r\n" +
"Connection: close\r\n\r\n");
unsigned long timeout = millis();
while (client.available() == 0) {
if (millis() - timeout > 5000) {
Serial.println(">>> Client Timeout !");
client.stop();
return;
// Melihat semua line balasan dari server dan menampilkan di Serial -------
while(client.available()){
Serial.print(line);
Client code :
#include <Adafruit_NeoPixel.h>
#ifdef __AVR__
#include <avr/power.h>
#endif
#define PIN 13
IPAddress IP(192,168,4,100);
IPAddress NETMASK(255,255,255,0);
IPAddress NETWORK(192,168,4,1);
// Menasukan LED RGB
Adafruit_NeoPixel strip = Adafruit_NeoPixel(60, PIN, NEO_GRB + NEO_KHZ800);
delay(10);
// Connect to WiFi network ------------------------------------------------
Serial.println(ssid);
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);
WiFi.config(IP, NETMASK, NETWORK);
Serial.println("");
server.begin();
// Menjalankan LED RGB ----------------------------------------------------
strip.begin();
strip.show();
if (!client) {
return;
delay(1);
client.flush();
int val;
if (req.indexOf("/sa/0") != -1){
strip.setPixelColor(4,0x000000); //LED menjadi mati -------------------
strip.show();
else if (req.indexOf("/sa/1") != -1){
strip.setPixelColor(4, 0xFF0000); //LED menjadi merah -----------------
strip.show();
else {
client.stop();
return;
client.flush();
