NodeMCU AP-Mode doesn't work
Posted: Sun Dec 04, 2016 7:40 am
Hi there,
I have a problem with creating a wifi controlled RGB-LED! I have one NodeMcu Board working as an AccessPoint only with this code:
And one NodeMCU-Board as an UDP-Server which controlls the LED:
So my problem is that I can noch send UDP data from my phone to the "Controller" using the AP's network. If I connect my phone to my router's network as well as the UDP-Server side everything works well but as soon as I switch to the AP's network no data is send. This wouldn't be a problem to use at home but I have to build this thing quite "standalone" so I dont have my router to connect to.
Can anyone help me fixing this issue or maybe could tell me a better way to do the task?
PS.: My native language is German, so sorry for my bad english!
MFG
Lukas
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#include <ESP8266mDNS.h>
const char *ssid = "RGB";
const char *password = "";
ESP8266WebServer server (80);
WiFi.softAP(ssid, password);
server.begin();
server.handleClient();
#include <WiFiUdp.h>
const char* ssid = "SSID";
const char* password = "PASSWORD";
unsigned int port = 9999;
char packetBuffer[255];
char ReplyBuffer[] = "acknowledged";
WiFiUDP Udp;
const int REDPIN = 12;
const int GREENPIN = 16;
const int BLUEPIN = 13;
void setup()
// set pin modes
pinMode(REDPIN, OUTPUT);
pinMode(GREENPIN, OUTPUT);
pinMode(BLUEPIN, OUTPUT);
digitalWrite(REDPIN, HIGH);
delay(300);
digitalWrite(REDPIN, LOW);
digitalWrite(GREENPIN, HIGH);
delay(300);
digitalWrite(GREENPIN, LOW);
digitalWrite(BLUEPIN, HIGH);
delay(300);
digitalWrite(BLUEPIN, LOW);
// begin serial and connect to WiFi
delay(100);
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.println("");
Udp.begin(port);
int value = 0;
void loop()
int packetSize = Udp.parsePacket();
if(packetSize) {
Serial.print("Received packet of size ");
Serial.println(packetSize);
Serial.print("From ");
IPAddress remoteIp = Udp.remoteIP();
Serial.print(remoteIp);
Serial.print(", port ");
Serial.println(Udp.remotePort());
// read the packet into packetBufffer
int len = Udp.read(packetBuffer, 255);
if (len > 0) {
packetBuffer[len] = 0;
Serial.println("Contents:");
Serial.println(packetBuffer);
Serial.write(packetBuffer);
// TEMP parse data from packet
char * temp;
Serial.print("Splitting string \"");
Serial.print(packetBuffer);
Serial.println("\"");
int r = 0;
int b = 0;
int g = 0;
temp = strtok (packetBuffer,":");
Serial.println(temp);
r = atoi(temp);
if(temp != NULL){
temp = strtok (NULL,":");
g = atoi(temp);
if(temp != NULL){
b = atoi(temp);
Serial.println(r);
Serial.println(g);
Serial.println(b);
analogWrite(REDPIN, r);
analogWrite(GREENPIN, g);
analogWrite(BLUEPIN, b);
// send a reply, to the IP address and port
// that sent us the packet we received
Udp.beginPacket(Udp.remoteIP(), Udp.remotePort());
Udp.write(ReplyBuffer);
Udp.endPacket();
MFG
Lukas
