I'm trying to send datas from my Arduino Mega 2560 to a web server.
Actually I'm be able to make a GET request to send a value to a php file in the web server but I Would like to send several datas using just one GET request. I found on google a way (using the simbol "&" to send 2 values to 2 differents variables in the SAME PHP FILE but I cannot find something about to send several values to different php file wich is my goal!
Is it possible? if not, is there a way to do it (maybe with more GET request) with no close and re-open the connection to the server every value sent? because this take some precoius second.....
I'm using the arduino library ESP8266.h
and this is my sketch:
#include "ESP8266.h"
#define SSID "mySSID" //Gnigni'_WIFI Eugeni Wi_Fi
#define PASSWORD "myPASSWORD" //fleugeniwifi
#define HOST_NAME "mySERVER"
#define HOST_PORT (80)
ESP8266 wifi(Serial1);
void setup(void)
Serial.print("setup begin\r\n");
Serial.print("FW Version:");
Serial.println(wifi.getVersion().c_str());
if (wifi.setOprToStationSoftAP()) {
Serial.print("to station + softap ok\r\n");
} else {
Serial.print("to station + softap err\r\n");
if (wifi.joinAP(SSID, PASSWORD)) {
Serial.print("Join AP success\r\n");
Serial.print("IP:");
Serial.println( wifi.getLocalIP().c_str());
} else {
Serial.print("Join AP failure\r\n");
if (wifi.disableMUX()) {
Serial.print("single ok\r\n");
} else {
Serial.print("single err\r\n");
Serial.print("setup end\r\n");
delay(2000);
void loop(void)
uint8_t buffer[1024] = {0};
if (wifi.createTCP(HOST_NAME, HOST_PORT)) {
Serial.print("create tcp ok\r\n");
} else {
Serial.print("create tcp err\r\n");
//the following line is my GET request
char *hello = "GET /biobot/write1.php?value=22HTTP/1.1\r\nHost: mySERVER\r\nConnection: close\r\n\r\n";
wifi.send((const uint8_t*)hello, strlen(hello));
uint32_t len = wifi.recv(buffer, sizeof(buffer), 10000);
if (len > 0) {
Serial.print("Received:[");
for(uint32_t i = 0; i < len; i++) {
Serial.print((char)buffer[i]);
Serial.print("]\r\n");
if (wifi.releaseTCP()) {
Serial.print("release tcp ok\r\n");
} else {
Serial.print("release tcp err\r\n");
delay(1000);
} else {
char *hello2 = "GET /biobot/write2.php?value=44 HTTP/1.1\r\nHost: peretti.ddns.net\r\nConnection: close\r\n\r\n"; // SE SI VUOLE FARE UNA POST PROVARE A MODIFICARE QUESTA RIGA
wifi.send((const uint8_t*)hello2, strlen(hello2));
uint32_t len2 = wifi.recv(buffer, sizeof(buffer), 10000);
if (len > 0) {
} else {
delay(1000);
}thanks to who will help me!!!
and if you have some more suggestions about this topic you are welcome to teach me
