By allenck
#76350 I'm trying to add a RTC to this module:
https://www.banggood.com/Wemos-ESP32-OL ... rehouse=CN
My hardware also includes a DHT22 temperature and humidity sensor.
First, I tried using the same pins for SDA and SDC as used by the SH1106 model (pins 5 & 4). That did not work. The RTC fails as soon as the display is initialized.There appears to be some sort of conflict between the OLED and the DS3231 RTC. So I installed the RTC on different SDA and SDC pins. The RTC code works as expected until the display is initialized just as before.
Code: Select allBegin serial
06/07/2018 14:43:39
RTC is newer than compile time. (this is expected)
Connecting to *********
WiFi connected
Web server running. Waiting for the ESP IP...
10.0.1.102
06/07/2018 14:43:54
RTC lost confidence in the DateTime!
85/165/2009 37:165:
-0.25C
Here is my sketch:
Code: Select all#include <DHT.h>
#include <DHT_U.h>
 * The MIT License (MIT)
 * Copyright (c) 2018 by ThingPulse, Daniel Eichhorn
 * Copyright (c) 2018 by Fabrice Weinberg
 * Permission is hereby granted, free of charge, to any person obtaining a copy
 * of this software and associated documentation files (the "Software"), to deal
 * in the Software without restriction, including without limitation the rights
 * to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
 * copies of the Software, and to permit persons to whom the Software is
 * furnished to do so, subject to the following conditions:
 * The above copyright notice and this permission notice shall be included in all
 * copies or substantial portions of the Software.
 * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
 * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
 * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
 * AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
 * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
 * OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
 * SOFTWARE.
 * ThingPulse invests considerable time and money to develop these open source libraries.
 * Please support us by buying our products (and not the clones) from
 * https://thingpulse.com
// Include the correct display library
// For a connection via I2C using Wire include
#include <Wire.h>  // Only needed for Arduino 1.6.5 and earlier
//#include "SSD1306Wire.h" // legacy include: `#include "SSD1306.h"`
// or #include "SH1106Wire.h", legacy include: `#include "SH1106.h"`
// For a connection via I2C using brzo_i2c (must be installed) include
//#include <brzo_i2c.h> // Only needed for Arduino 1.6.5 and earlier
//#include "SSD1306Brzo.h"
#include "SH1106.h"
//#include "SH1106Brzo.h"
// For a connection via SPI include
// #include <SPI.h> // Only needed for Arduino 1.6.5 and earlier
// #include "SH1106SPi.h"
// Include custom images
#include "images.h"
//#include "DS3231.h"
//DS3231 Clock;
#include <RtcDS3231.h> //RTC library
RtcDS3231<TwoWire> Rtc(Wire);
bool Century=false;
bool h12;
bool PM;
byte ADay, AHour, AMinute, ASecond, ABits;
bool ADy, A12h, Apm;
// Initialize the OLED display using SPI
// D5 -> CLK
// D7 -> MOSI (DOUT)
// D0 -> RES
// D2 -> DC
// D8 -> CS
// SSD1306Spi        display(D0, D2, D8);
// or
// SH1106Spi         display(D0, D2);
// Initialize the OLED display using brzo_i2c
// D3 -> SDA
// D5 -> SCL
// SSD1306Brzo display(0x3c, D3, D5);
// or
//SH1106Brzo  display(0x3c, D3, D5);
//SSD1306Brzo  display(0x3c, 5, 4);
// Initialize the OLED display using Wire library
//SSD1306Wire  display(0x3c, D3, D5);
//SSD1306Wire display(0x3c, 5, 4);
//SH1106 display(0x3c, D3, D5);
SH1106 display(0x3c, 5, 4);
//SH1106Brzo display(0x3c, 5, 4);
#define DEMO_DURATION 3000
typedef void (*Demo)(void);
#include "DHT.h"
#define DHTPIN 2     // what pin we're connected to
#define DHTTYPE DHT22   // DHT 22  (AM2302)
DHT dht(DHTPIN, DHTTYPE); //// Initialize DHT sensor for normal 16mhz Arduino
// Replace with your network details
const char* ssid = "*******";
const char* password = "*********";
// Web Server on port 80
WiFiServer server(80);
// Temporary variables
static char celsiusTemp[7];
static char fahrenheitTemp[7];
static char humidityTemp[7];
int demoMode = 0;
int counter = 1;
  Serial.begin(74880);
  Serial.println("Begin serial");
//--------RTC SETUP ------------
    // if you are using ESP-01 then uncomment the line below to reset the pins to
    // the available pins for SDA, SCL
    // Wire.begin(0, 2); // due to limited pins, use pin 0 and 2 for SDA, SCL
    Wire.begin(14,12);
    Rtc.Begin();
    RtcDateTime compiled = RtcDateTime(__DATE__, __TIME__);
    printDateTime(compiled);
    if (!Rtc.IsDateTimeValid())
        // Common Cuases:
        //    1) first time you ran and the device wasn't running yet
        //    2) the battery on the device is low or even missing
        Serial.println("RTC lost confidence in the DateTime!");
        // following line sets the RTC to the date & time this sketch was compiled
        // it will also reset the valid flag internally unless the Rtc device is
        // having an issue
        Rtc.SetDateTime(compiled);
    if (!Rtc.GetIsRunning())
        Serial.println("RTC was not actively running, starting now");
        Rtc.SetIsRunning(true);
    RtcDateTime now = Rtc.GetDateTime();
    if (now < compiled)
        Serial.println("RTC is older than compile time!  (Updating DateTime)");
    else if (now > compiled)
        Serial.println("RTC is newer than compile time. (this is expected)");
    else if (now == compiled)
        Serial.println("RTC is the same as compile time! (not expected but all is fine)");
    // never assume the Rtc was last configured by you, so
    // just clear them to your needed state
    Rtc.Enable32kHzPin(false);
    Rtc.SetSquareWavePin(DS3231SquareWavePin_ModeNone);
  // Connecting to WiFi network
  Serial.println(ssid);
  WiFi.begin(ssid, password);
    Serial.print(".");
  Serial.println("");
  // Starting the web server
  server.begin();
  Serial.println("Web server running. Waiting for the ESP IP...");
  delay(10000);
  // Printing the ESP IP address
        // Common Cuases:
        //    1) the battery on the device is low or even missing and the power line was disconnected
    printDateTime(now);
// Initialising the UI will init the display too.
  display.init();
  display.flipScreenVertically();
  display.setFont(ArialMT_Plain_10);
void drawFontFaceDemo() {
    // Font Demo1
    // create more fonts at http://oleddisplay.squix.ch/
    display.setTextAlignment(TEXT_ALIGN_LEFT);
    display.drawString(0, 0, "Hello world");
    display.setFont(ArialMT_Plain_16);
    display.drawString(0, 10, "Hello world");
    display.setFont(ArialMT_Plain_24);
    display.drawString(0, 26, "Hello world");
void drawTemperature() {
    // Font Demo1
    display.drawString(0, 0, "Temperature");
    char str[10];
    float tf = dht.readTemperature(true, false);
    sprintf(str, "%.2f°F", tf);
    display.drawString(0, 10, str);
    float tc = dht.convertFtoC(tf);
    sprintf(str, "%.2f°C", tc);
    display.drawString(0, 34, str);
void drawHumidity() {
    // Font Demo1
    display.drawString(0, 0, "Humidity/Heat Index:");
    char str[10];
    float h = dht.readHumidity(false);
    sprintf(str, "%.2f%%", h);
    float x = dht.computeHeatIndex(tf, h, true);
    sprintf(str, "%.2f°F", x);
void drawTextFlowDemo() {
    display.drawStringMaxWidth(0, 0, 128,
      "Lorem ipsum\n dolor sit amet, consetetur sadipscing elitr, sed diam nonumy eirmod tempor invidunt ut labore." );
void drawTextAlignmentDemo() {
    // Text alignment demo
  // The coordinates define the left starting point of the text
  display.drawString(0, 10, "Left aligned (0,10)");
  // The coordinates define the center of the text
  display.setTextAlignment(TEXT_ALIGN_CENTER);
  display.drawString(64, 22, "Center aligned (64,22)");
  // The coordinates define the right end of the text
  display.setTextAlignment(TEXT_ALIGN_RIGHT);
  display.drawString(128, 33, "Right aligned (128,33)");
void drawRectDemo() {
      // Draw a pixel at given position
    for (int i = 0; i < 10; i++) {
      display.setPixel(i, i);
      display.setPixel(10 - i, i);
    display.drawRect(12, 12, 20, 20);
    // Fill the rectangle
    display.fillRect(14, 14, 17, 17);
    // Draw a line horizontally
    display.drawHorizontalLine(0, 40, 20);
    display.drawVerticalLine(40, 0, 20);
void drawCircleDemo() {
  for (int i=1; i < 8; i++) {
    display.setColor(WHITE);
    display.drawCircle(32, 32, i*3);
    if (i % 2 == 0) {
      display.setColor(BLACK);
    display.fillCircle(96, 32, 32 - i* 3);
void drawProgressBarDemo() {
  int progress = (counter / 5) % 100;
  // draw the progress bar
  display.drawProgressBar(0, 32, 120, 10, progress);
  // draw the percentage as String
  display.drawString(64, 15, String(progress) + "%");
void drawImageDemo() {
    // see http://blog.squix.org/2015/05/esp8266-nodemcu-how-to-create-xbm.html
    // on how to create xbm files
    display.drawXbm(34, 14, WiFi_Logo_width, WiFi_Logo_height, WiFi_Logo_bits);
Demo demos[] = {/*drawFontFaceDemo, drawTextFlowDemo, drawTextAlignmentDemo, drawRectDemo, drawCircleDemo, drawProgressBarDemo,*/ drawImageDemo, drawTemperature, drawHumidity};
int demoLength = (sizeof(demos) / sizeof(Demo));
long timeSinceLastModeSwitch = 0;
   // clear the display
  display.clear();
  // draw the current demo method
  demos[demoMode]();
  display.drawString(10, 128, String(millis()));
  // write the buffer to the display
  display.display();
   if (millis() - timeSinceLastModeSwitch > DEMO_DURATION) {
    demoMode = (demoMode + 1)  % demoLength;
    timeSinceLastModeSwitch = millis();
  counter++;
  delay(10);
  //sht.readSensor();
  // Listenning for new clients
  if (client) {
    Serial.println("New client");
    // bolean to locate when the http request ends
    boolean blank_line = true;
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        if (c == '\n' && blank_line) {
            // Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
            float h = dht.readHumidity(true);
            // Read temperature as Celsius (the default)
            float t = dht.readTemperature(false, false);
            // Read temperature as Fahrenheit (isFahrenheit = true)
            float f = dht.convertCtoF(t);
            // Check if any reads failed and exit early (to try again).
            if (isnan(h) || isnan(t) || isnan(f)) {
              Serial.println("Failed to read from SHT sensor!");
              strcpy(celsiusTemp,"Failed");
              strcpy(fahrenheitTemp, "Failed");
              strcpy(humidityTemp, "Failed");
            else {
              // Computes temperature values in Celsius + Fahrenheit and Humidity
              float hic = dht.readTemperature(false,false);
              //dht.computeHeatIndex(t, h, false);
              dtostrf(hic, 6, 2, celsiusTemp);
              float hif = dht.convertCtoF(hic);
              //dht.computeHeatIndex(f, h);
              dtostrf(hif, 6, 2, fahrenheitTemp);
              dtostrf(h, 6, 2, humidityTemp);
            client.println("HTTP/1.1 200 OK");
            client.println("Content-Type: text/html");
            client.println("Connection: close");
            client.println();
            // your actual web page that displays temperature and humidity
            client.println("<!DOCTYPE HTML>");
            client.println("<html>");
            client.println("<head></head><body><h1>ESP8266 - Temperature and Humidity</h1><h3>Temperature in Celsius: ");
            client.println(celsiusTemp);
            client.println("&deg;C</h3><h3>Temperature in Fahrenheit: ");
            client.println(fahrenheitTemp);
            client.println("&deg;F</h3><h3>Humidity: ");
            client.println(humidityTemp);
            client.println("%</h3><h3>");
            client.println("</body></html>");
            break;
        if (c == '\n') {
          // when starts reading a new line
          blank_line = true;
        else if (c != '\r') {
          // when finds a character on the current line
          blank_line = false;
    // closing the client connection
    delay(1);
    client.stop();
    Serial.println("Client disconnected.");
        // Common Cuases:
    printDateTime(now);
  RtcTemperature temp = Rtc.GetTemperature();
  temp.Print(Serial);
  // you may also get the temperature as a float and print it
    // Serial.print(temp.AsFloatDegC());
    Serial.println("C");
#define countof(a) (sizeof(a) / sizeof(a[0]))
void printDateTime(const RtcDateTime& dt)
    char datestring[20];
    snprintf_P(datestring,
            countof(datestring),
            PSTR("%02u/%02u/%04u %02u:%02u:%02u"),
            dt.Month(),
            dt.Day(),
            dt.Year(),
            dt.Hour(),
            dt.Minute(),
            dt.Second() );
    Serial.print(datestring);
I would like to be able to plot temperature and humidity vs time.
Does anybody have any idea why the RTC is failing after the SH1106 is initialized??
By rudy
#76352 I took out the DHT stuff and hard coded values. I removed what I didn't have and was not necessary for the RTC and the OLED. And in the end they both didn't work together.
I tried a different route. I decided to take a minimal RTC example and add in the minimum OLED code. And I have them both working together.
The OLED I have is the SSD1306 so the included file is different. I also used GPIO0 and GPIO2 for the I2C lines.
I don't know what is wrong with your code. I don't have anymore time to look at it again. But maybe you can use what I have here to get your hardware working together and then figure out why your program doesn't work.
Code: Select all//  Get date and time from DS3231 and display it on OLED
// Rtc_by_Makuna library  https://github.com/Makuna/Rtc
#include <Wire.h> // must be included here so that Arduino library object file references work
SSD1306  display(0x3c, 0, 2);   //display(I2C address, SDA, SCL)
void setup ()
  Serial.print("compiled: ");
  Serial.print(__DATE__);
  Serial.println(__TIME__);
  Rtc.Begin();
    // Common Cuases:
    // having an issue
  if (now < compiled)
  display.init();  // Initialising the UI will init the display too.
  display.flipScreenVertically();   // up side down or straight
  display.setFont(ArialMT_Plain_10);  //default font. Create more fonts at http://oleddisplay.squix.ch/
void loop ()
    // Common Cuases:
  printDateTime(now);
  OLEDprintDateTime(now);
  delay(1000);    //
             dt.Month(),
             dt.Day(),
             dt.Year(),
             dt.Hour(),
             dt.Minute(),
             dt.Second() );
void OLEDprintDateTime(const RtcDateTime& dt)
  display.clear();    // clear the display
             PSTR("%02u/%02u/%04u"),
             dt.Month(),
             dt.Day(),
             dt.Year() );
  display.setFont(ArialMT_Plain_24);    // change font
  display.drawString(0, 10, datestring);   // draw string (column(0-127), row(0-63, "string")
             PSTR("%02u:%02u:%02u"),
             dt.Hour(),
             dt.Minute(),
             dt.Second() );
  display.drawString(0, 40, datestring);   // draw string (column(0-127), row(0-63, "string")
  display.display();      //display all you have in display memory
  delay(10);  // give some time to finish function loops
