am having issues sending HTTP GET requests to a GoPro Camera. I have gotten this to work for 3 different GoPro cameras, it is just the newer Hero 5 that is giving me problems. It is probably something simple, but the client connection works and the HTTP requests work right after the wifi connections have been reset on the camera, but if the ESP8266 is reset after a first WiFi connection, it connects to the WiFi fine, but all HTTP requests return a -1 HTTP Code and the client fails to connect.
I've tried calling client.flush(), client.stop() and just about anything else I can think of or find online. The only way to make the commands work again is to reset the WiFi connections on the camera. If I connect using my computer, I have no problem sending the commands from Google Chrome as shown in the attached picture. I've tried using the regular ESP8266WiFi library and the ESP8266HTTPClient library as shown below. Any help would be appreciated! Thanks
Source Code - Arduino IDE Sketch
// Use WiFiclient class to create TCP connections
WiFiClient client;
HTTPClient http;
const char* ssid = "GP25000830";
const char* password = "vault9291";
String wifi_ssid = "GP25000830";
String wifi_password = "vault9291";
const char* host = "10.5.5.9";
const int httpPort = 80;
String StartURL = "/gp/gpControl/command/shutter?p=1";
void Trigger() {
return;
//Command for starting recording
client.print(String("GET ") + StartURL + " HTTP/1.1\r\n" +
"Host: " + host + "\r\n" +
"User-Agent: RCRemote\r\n" +
"Connection: close\r\n\r\n");
Serial.println("Triggering");
delay(20);
void Trigger_http() {
http.begin("http://10.5.5.9/gp/gpControl/command/shutter?p=1");
int httpCode = http.GET();
Serial.print("Http Code is: ");
Serial.println(httpCode);
http.end();
WiFi.disconnect(true);
WiFi.disconnect();
Serial.println(ssid);
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
Serial.print("IP address: ");
client.flush();
Trigger();
delay(5000);
Trigger_http();
delay(5000);
}Debug Messages
This is just the debug messages generated via the Serial Port (Debug Level = HTTP_CLIENT). The sketch output is intermixed with the debug messages.
SDK:3.0.0-dev(c0f7b44)/Core:2.5.0-beta2=20499902/lwIP:STABLE-2_1_2_RELEASE/glue:1.0-4-gc434c6f/BearSSL:2398cc6
Connecting to GP25000830
mode : sta(38:2b:78:04:3b:81)
add if0
.....scandone
state: 0 -> 2 (b0)
.state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 1
cnt
connected with GP25000830, channel 6
dhcp client start...
....ip:10.5.5.100,mask:255.255.255.0,gw:10.5.5.9
WiFi connected
IP address: 10.5.5.100
connection failed
pm open,type:2 0
[HTTP-Client][begin] url: http://10.5.5.9/gp/gpControl/command/shutter?p=1
[HTTP-Client][begin] host: 10.5.5.9 port: 80 url: /gp/gpControl/command/shutter?p=1
[HTTP-Client] failed connect to 10.5.5.9:80
[HTTP-Client][returnError] error(-1): connection refused
Http Code is: -1
[HTTP-Client][end] tcp is closed
connection failed
Http Code is: -1
[HTTP-Client][end] tcp is closedIf you need any other details, please let me know. Thanks!
