Help esp Dmx dimmer via MQTT errors
PostPosted: Thu Jan 24, 2019 9:36 pm
by papas_17
hi so i use an esp 8266 to control the dmx dimmer of some lights via mqtt and nodered
The only problem i come across after a few minutes of use it resets at the begining mayebe 30' and after every 10’or more minutes and send these errors :
Code: Select all`/*
#include <espDMX.h>
#include <PubSubClient.h>
// Update these with values suitable for your network.
const char* ssid = "ssid";
const char* password = "password";
const char* mqtt_server = "192.168.0.12";
WiFiClient espClient;
PubSubClient client(espClient);
uint32_t lastMsg = 0;
char msg[50];
uint8_t dmxPayload[2];
uint16_t value = 0;
void setup_wifi() {
delay(10);
Serial.println(ssid);
WiFi.begin(ssid, password);
randomSeed(micros());
Serial.println("");
void callback(char* topic, byte* payload, unsigned int length) {
//Serial.println(length);
// Serial.print("Message arrived [");
// Serial.print(topic);
// Serial.print("] ");
// for (int i = 0; i < length; i++) {
// Serial.print((char)payload);
// Serial.println();
// Should really check the topic matches the exact one your subscribed to before using value
msg = (char)payload;
msg[length] = 0;
int x = atoi(msg);
Serial.println(x);
dmxPayload[0] = (byte)x;
dmxB.setChans(dmxPayload, 1);
void reconnect() {
// Loop until we're reconnected
while (!client.connected()) {
Serial.print("Attempting MQTT connection...");
// Attempt to connect
if (client.connect("group1","user","password")) {
Serial.println("connected");
// Once connected, publish an announcement...
client.publish("outlight/dmx1/", "On Dmx Esp");
// ... and resubscribe
client.subscribe("inlight/dmx1/");
} else {
Serial.print("failed, rc=");
Serial.print(client.state());
Serial.println(" try again in 5 seconds");
// Wait 5 seconds before retrying
delay(5000);
// Start dmxA, status LED on pin 12 with full intensity
dmxB.begin();
setup_wifi();
client.setServer(mqtt_server, 1883);
client.setCallback(callback);
delay(2000);
if (!client.connected()) {
reconnect();
client.loop();
if (millis() - lastMsg > 60000) {
lastMsg = millis();
snprintf (msg, 49, "On Dmx Esp");
//snprintf (msg, 49, "On Dmx Esp #%ld", value++);
//Send free memory ram
// uint32_t free = ESP.getFreeHeap();
// itoa(free, msg, 10);
//  Serial.print("Publish message: ");
//  Serial.println(msg);
client.publish("outlight/dmx1/", msg);
delay(10);
ERRORS
Code: Select all`ets Jan 8 2013,rst cause:4, boot mode:(3,6)
wdt reset
tail 8
chksum 0x2d
csum 0x2d
vbb28d4a3
~ld
Connecting to hkhkhkhk
WiFi connected
IP address:
192.168.0.110
Attempting MQTT connection...connected
wdt reset
tail 8
chksum 0x2d
csum 0x2d
vbb28d4a3
~ld
WiFi connected
IP address:
192.168.0.110`
any help will be really appreciated because I can’t find how to solve the problem .
The only think I know is that it has something to do with watchdog and the WiFi .
thanks in advance
chris
