It’s based on a library called wifimanager with a cool feature called auto connect AP that will log you on WiFi. Well basically it has two buttons for turning on relays (sorry I’m still green as grass) that would be perfect for my use. The sketch will show up on my iPhone and ask for credentials and disappear like it’s connected but I can’t connect to the ip listed in sketch to pull up buttons in next step. Could anyone give me a hand?
Thank you in advance for your time and energy
#include <ESP8266WiFi.h> // https://github.com/esp8266/Arduino
#include <DNSServer.h>
#include <ESP8266WebServer.h>
#include <WiFiManager.h> // https://github.com/tzapu/WiFiManager
#include <string.h>
ESP8266WebServer server(80);
int relay1_pin = 0;
int relay2_pin = 2;
boolean relay1_state = true; // Turned on by default
boolean relay2_state = true; // Turned on by default
// See http://modtronix.com/mod-rly2-5v.html <- Active Low
boolean relay_module_active = LOW; // Are the relays turned on by going HIGH or LOW?
String page = "<!DOCTYPE html>\n<html>\n<head>\n<meta http-equiv=Content-Type content=\"text/html; charset=utf-8\" />\n<meta http-equiv=X-UA-Compatible content=\"IE=8,IE=9,IE=10\">\n<meta name=viewport content=\"width=device-width, initial-scale=1.0, maximum-scale=1.0, user-scalable=0\"/>\n<style>body{font-family:sans-serif}.switch{cursor:pointer;width:5.5em;border:1px solid #5f645b;color:#fff;border-radius:.8em;margin-left:20px}.toggle,.state{margin:.1em;font-size:130%;font-weight:normal;text-align:center;float:left}.toggle{width:1.1em;background-color:#f5f5f5;color:#000;text-align:center;border:1px solid grey;border-radius:.5em;margin-right:.1em;margin-left:.2em}.state{padding-top:.05em;width:2em}.on{background-color:#56c94d}.off{background-color:#eceeef;color:#aaaab8}.on .toggle{float:right}.off .toggle{float:left}.clearfix{clear:both}table td{vertical-align:middle}table h2{margin:0;padding:0;font-weight:normal;margin-top:4px}</style>\n<script>function toggle(a){document.location.href=\"relay\"+a+\"/toggle\"};</script>\n</head>\n<body>\n<h1>Relay Mangager</h1>\n<table border=0>\n<tr><td>\n<h2>Relay 1</h1>\n</td><td>\n<div class=\"switch {{relay1_state}}\" onclick=toggle(1)>\n<div class=toggle> </div>\n<div class=state>{{relay1_state}}</div><br class=clearfix />\n</div>\n</td></tr>\n<tr><td>\n<h2>Relay 2</h1>\n</td><td>\n<div class=\"switch {{relay2_state}}\" onclick=toggle(2)>\n<div class=toggle> </div>\n<div class=state>{{relay2_state}}</div><br class=clearfix />\n</div>\n</td>\n</tr>\n</table>\n</body>\n</html>";
IPAddress sta_ip = IPAddress(192,168,0,20);
IPAddress sta_gw = IPAddress(192,168,0,1);
IPAddress sta_sn = IPAddress(255,255,255,0);
String get_human_state(bool relay_state){
if(relay_state == 1){
return "on";
}else{
return "off";
String get_page(){
String x = page;
x.replace("{{relay1_state}}", get_human_state(relay1_state));
x.replace("{{relay2_state}}", get_human_state(relay2_state));
return x;
void handle_root() {
Serial.println("Request incoming...");
server.send(200, "text/html", get_page());
delay(100);
Serial.println("Request handled.");
void handle_not_found() {
Serial.println("404 Not Found ");
server.send(404, "text/plain", "Not Found. You requested \"" + server.uri() + "\"");
delay(100);
int get_relay_pin(int relay_number){
if(relay_number == 1){
return relay1_pin;
if(relay_number == 2){
return relay2_pin;
bool get_relay_state(int relay_number){
if (relay_number == 1){
return relay1_state;
if (relay_number == 2){
return relay2_state;
void set_relay_state(int relay_number, bool state){
relay1_state = state;
relay2_state = state;
void handle_relay() {
int relay_number;
int relay_pin;
if (server.uri() == "/api/relay1"){
relay_pin = relay1_pin;
relay_number = 1;
}else if(server.uri() == "/api/relay2"){
relay_pin = relay2_pin;
relay_number = 2;
if (server.method() == HTTP_GET){
Serial.println("GET REQUESTed");
server.send(200, "text/json", "{\"state\": " + String(get_relay_state(relay_number)) + "}");
}else if (server.method() == HTTP_POST){
Serial.println("POST REQUESTed");
for ( uint8_t i = 0; i < server.args(); i++ ) {
Serial.println( "" + server.argName ( i ) + ": " + server.arg ( i ));
if (server.argName(i) == "state"){
set_relay(relay_number, bool(server.arg(i).toInt()));
server.send(200, "text/json", "{\"state\": " + String(get_relay_state(relay_number)) + ", \"set\": 1}");
}else{
server.send(501, "text/json", "{\"error\": \"Not Implemented: " + String(server.method()) + "\"}");
delay(100);
void handle_toggle(){
int relay_number;
int relay_pin;
if (server.uri() == "/relay1/toggle"){
relay_number = 1;
}else if(server.uri() == "/relay2/toggle"){
relay_number = 2;
set_relay(relay_number, !get_relay_state(relay_number));
server.sendHeader("Location", "/", true);
server.send (302, "text/plain", "");
server.client().stop();
void set_relay(int relay_number, bool state){
// Responsible for implementin the pin change and keeping track of the pin state.
// This method could be less verbose, but I like easily readable code.
if (state == 1){
// We want to turn this relay on, so we need to take it low
digitalWrite(get_relay_pin(relay_number), relay_module_active);
set_relay_state(relay_number, 1);
}else{
// We want to turn this relay off, so we need to take it high
digitalWrite(get_relay_pin(relay_number), !relay_module_active);
set_relay_state(relay_number, 0);
// Set up the pins and apply the default state.
pinMode(relay1_pin, OUTPUT);
pinMode(relay2_pin, OUTPUT);
set_relay(1,relay1_state);
set_relay(2,relay2_state);
WiFiManager wifiManager;
//wifiManager.resetSettings();
wifiManager.setTimeout(180);
wifiManager.setSTAStaticIPConfig(sta_ip, sta_gw, sta_sn);
if(!wifiManager.autoConnect("AutoConnectAP")) {
Serial.println("Failed to connect and hit timeout");
delay(3000);
ESP.reset();
delay(5000);
Serial.println("Connected to Wifi...");
server.on("/", handle_root);
server.on("/api/relay1", handle_relay);
server.on("/api/relay2", handle_relay);
server.on("/relay1/toggle", handle_toggle);
server.on("/relay2/toggle", handle_toggle);
server.onNotFound (handle_not_found);
server.begin();
Serial.println("Server Started!");
server.handleClient();
