Problem w/ ‘ESP8266 Sketch Data Upload’ in Arduino IDE
Posted: Wed Nov 27, 2019 1:53 pm
⚫ Compilation and sketch upload
Executable segment sizes:
IROM : 233056 - code in flash (default or ICACHE_FLASH_ATTR)
IRAM : 27064 / 32768 - code in IRAM (ICACHE_RAM_ATTR, ISRs...)
DATA : 1236 ) - initialized variables (global, static) in RAM/HEAP
RODATA : 1668 ) / 81920 - constants (global, static) in RAM/HEAP
BSS : 24960 ) - zeroed variables (global, static) in RAM/HEAP
/Users/gregorybaker/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506/bin/xtensa-lx106-elf-size -A /var/folders/h7/wf7nxlvj6jj3r1hw4ghnj0yw0000gn/T/arduino_build_283738/Blink.ino.elf
Sketch uses 263024 bytes (25%) of program storage space. Maximum is 1044464 bytes.
Global variables use 27864 bytes (34%) of dynamic memory, leaving 54056 bytes for local variables. Maximum is 81920 bytes.
/Users/gregorybaker/Library/Arduino15/packages/esp8266/tools/python3/3.7.2-post1/python3 /Users/gregorybaker/Library/Arduino15/packages/esp8266/hardware/esp8266/2.6.1/tools/upload.py --chip esp8266 --port /dev/cu.usbserial-0001 --baud 115200 --before default_reset --after hard_reset /var/folders/h7/wf7nxlvj6jj3r1hw4ghnj0yw0000gn/T/arduino_build_283738/Blink.ino.bin
esptool.py v2.8
Serial port /dev/cu.usbserial-0001
Connecting....
Chip is ESP8266EX
Features: WiFi
Crystal is 26MHz
MAC: 60:01:94:75:4d:ba
Uploading stub...
Running stub...
Stub running...
Configuring flash size...
Auto-detected Flash size: 4MB
Compressed 267184 bytes to 194570...
Writing at 0x00000000... (8 %)
Writing at 0x0002c000... (100 %)
Wrote 267184 bytes (194570 compressed) at 0x00000000 in 17.2 seconds (effective 124.5 kbit/s)...
Hash of data verified.
Leaving...
Hard resetting via RTS pin...
⚫ No problems until trying to upload the sketch data directory:
[SPIFFS] data : /Users/gregorybaker/Desktop/new201122/Blink/data
[SPIFFS] size : 1000
[SPIFFS] page : 256
[SPIFFS] block : 8192
/Blink.txt
[SPIFFS] upload : /var/folders/h7/wf7nxlvj6jj3r1hw4ghnj0yw0000gn/T/arduino_build_283738/Blink.spiffs.bin
[SPIFFS] address : 0x300000
[SPIFFS] reset : --before default_reset --after hard_reset
[SPIFFS] port : /dev/cu.usbserial-0001
[SPIFFS] speed : 115200
[SPIFFS] python : python
[SPIFFS] uploader : /Users/gregorybaker/Library/Arduino15/packages/esp8266/hardware/esp8266/2.6.1/tools/upload.py
usage: esptool write_flash [-h] [--erase-all]
[--flash_freq {keep,40m,26m,20m,80m}]
[--flash_mode {keep,qio,qout,dio,dout}]
[--flash_size FLASH_SIZE]
[--spi-connection SPI_CONNECTION] [--no-progress]
[--verify] [--encrypt]
[--ignore-flash-encryption-efuse-setting]
[--compress | --no-compress]
<address> <filename> [<address> <filename> ...]
esptool write_flash: error: argument <address> <filename>: Must be pairs of an address and the binary filename to write there
SPIFFS Upload failed!
⚫ I do not understand the issues here well enough to fix them and need some help.
PORT::
Last login: Wed Nov 27 12:33:21 on ttys000
gregorybaker@Gregorys-MBP-4 ~ % ls /dev/tty.*
/dev/tty.Bluetooth-Incoming-Port /dev/tty.usbserial-0001
PYTHON::
gregorybaker@Gregorys-MBP-4 ~ % python
Python 2.7.17 (v2.7.17:c2f86d86e6, Oct 19 2019, 16:24:34)
[GCC 4.2.1 (Apple Inc. build 5666) (dot 3)] on darwin
Type "help", "copyright", "credits" or "license" for more information.
>>> ^D
ESPTOOL::
gregorybaker@Gregorys-MBP-4 ~ % pip install esptool
DEPRECATION: Python 2.7 will reach the end of its life on January 1st, 2020. Please upgrade your Python as Python 2.7 won't be maintained after that date. A future version of pip will drop support for Python 2.7. More details about Python 2 support in pip, can be found at https://pip.pypa.io/en/latest/developme ... -2-support
Requirement already satisfied: esptool in /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/site-packages/esptool-2.8.dev0-py2.7.egg (2.8.dev0)
Requirement already satisfied: pyserial>=3.0 in /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/site-packages/pyserial-3.4-py2.7.egg (from esptool) (3.4)
Requirement already satisfied: pyaes in /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/site-packages/pyaes-1.6.1-py2.7.egg (from esptool) (1.6.1)
Requirement already satisfied: ecdsa in /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/site-packages/ecdsa-0.14.1-py2.7.egg (from esptool) (0.14.1)
Requirement already satisfied: six in /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/site-packages/six-1.13.0-py2.7.egg (from ecdsa->esptool) (1.13.0)
⚫ Thank you for your time in just looking; hopefully, you can understand and help me.
Greg
