By sorh
#86159 I was trying to add some custom methods to a base class using inheritance but I just can't get my head around this and it keeps failing compilation.
I'm probably making some basic stupid error, please have a look:
Code: Select all#include "FS.h"
class Filesystem : public FS {
public:
    void Filesystem::mount() {
        if (!Filesystem::begin())
            Serial.println("Failed to mount file system");
        else {
            Serial.println("File system mounted.");
}myFiles;
    Serial.println("Mounting FS...");
    myFiles.mount();
Compiler output:
Code: Select allCompiling 'filesystem' for 'Generic ESP8266 Module'
filesystem.ino: 6:10: error: extra qualification 'Filesystem::' on member 'mount' [-fpermissive]
     void Filesystem*: mount() {
filesystem.ino: 16:2: error: use of deleted function 'Filesystem::Filesystem()
   }myFile
filesystem.ino:4: note  Filesystem  Filesystem() is implicitly deleted because the default definition would be ill-formed
 class Filesystem *: public FS {
filesystem.ino: 4:7: error: no matching function for call to 'fs::FS::FS()
Error compiling project sources
filesystem.ino:4: note  candidates are
filesystem.ino:2: In file included from
FS.h:201: note  fs  FS  FS(fs  FSImplPtr)
     FS(FSImplPtr impl) *: _impl(impl) { timeCallback = _defaultTimeCB; }
FS.h:201: note    candidate expects 1 argument, 0 provided
FS.h:198: note  fs  FS  FS(const fs  FS&)
   class FS
FS.h:198: note    candidate expects 1 argument, 0 provided
FS.h:198: note  fs  FS  FS(fs  FS&&)
Build failed for project 'filesystem'
By sorh
#86168 Thanks, but not much has changed:
filesystem.ino: 14:2: error: use of deleted function 'Filesystem::Filesystem()
   }myFiles
filesystem.ino:3: note  Filesystem  Filesystem() is implicitly deleted because the default definition would be ill-formed
filesystem.ino: 3:7: error: no matching function for call to 'fs::FS::FS()
filesystem.ino:3: note  candidates are
filesystem.ino:1: In file included from
   class FS
By RichardS
#86171 Little lesson "simple" inheritance not always that simple :-)
https://stackoverflow.com/questions/366 ... onstructor
https://github.com/espressif/arduino-es ... c/FS.h#L89
#include <SPIFFS.h>
  public:
    Filesystem() : FS(SPIFFS) {}; // because class FS has a constructor that needs a parameter it must be called here !!!see github link!!!
    void mount() {
      //if (begin()) {}// there is no member begin() in class FS
      if (open("filename", "r")) // but there is a member called open() so we try it here
      else {
  Filesystem myFiles;
  myFiles.mount();
Tested and compiles and works fine.
RichardS
