- Mon Jun 15, 2020 11:41 pm
#87556
Try adding this code line after the declaration of wifi client:
This make you are able to stablish an insecure connection. But remember, is not secure.
Note:
If you are doing an IoT device, I recommend you use MQTT protocol, is such faster than HTTP, lightweight, you can save memory usage. When I test my ESP turning on a light with HTTP I noticed a small delay, but with MQTT was instant. MQTT is designed for communication M2M, ensures high delivery guarantee. Also, with Node-RED in the server side made more easy programing what you do with the data, I use it as GateWay. HTTP have the advantage that is scalable and can be use it in many context, but for IoT device is better be faster.
If you want to have one secure, you need add more code and certs. I don't know if the certs are necessary, I never try a connection without this, because I using a SSL connection, that means is necessary for me, but try without it.
Code: Select all//add the following libraries
#include <time.h>
#include <FS.h>
#include <LittleFS.h>
#include <CertStoreBearSSL.h>
BearSSL::CertStore certStore;
//A function for sync time, secure connections need synched clock
void setClock() {
// Replace the first 0 with your time zone multiply by 3600, is not necessary the code work for me, but if you want your time zone
// something like 4 * 3600
configTime(0 * 3600, 0, "pool.ntp.org", "time.nist.gov"); // UTC
Serial.print(F("Waiting for NTP time sync: "));
time_t now = time(nullptr);
while (now < 8 * 3600 * 2) {
yield();
Serial.print(F("."));
Serial.println(F(""));
struct tm timeinfo;
gmtime_r(&now, &timeinfo);
Serial.print(F("Current time: "));
Serial.println(asctime(&timeinfo)); //print time in 0 time zone
//Serial.println(ctime(&now)); // print time in your time zone
//add this in your setup
//you need download and upload the certs to the file system before run these lines
//try without it
LittleFS.begin();
int numCerts = certStore.initCertStore(LittleFS, PSTR("/certs.idx"), PSTR("/certs.ar"));
Serial.print(F("Number of CA certs read: "));
Serial.println(numCerts);
if (numCerts == 0) {
Serial.println(F("No certs found. Did you run certs-from-mozill.py and upload the LittleFS directory before running?"));
return; // Can't connect to anything w/o certs!
//add this in your loop
setClock();
//add BearSSL::
BearSSL::WiFiClientSecure client;
//try without certs
bool mfln = client.probeMaxFragmentLength("https://api.mydomain.com/storereadings", 443, 1024);
Serial.printf("MFLN supported: %s\n", mfln ? "yes" : "no");
if (mfln) {
client.setBufferSizes(1024, 1024);
client.setCertStore(&certStore);
//your http code start here
HTTPClient http;
//{...} Download the certs from this script (
https://github.com/arduino/esp8266/blob ... mozilla.py), is from official repo of ESP8266.
You need to put certs-from-mozilla.py in the same folder of your project and run from the console. If you are on windows, you need download OpenSSL and add to the path. Git come with
"openSSL.exe", you only need to add to the path, I recommend use Git because the official OpenSSL's web page doesn't have an installer for windows, so you need third party web, you have risk of download virus or malware. Certs need one more file add to the path,
"ar.exe", this come with the ESP8266 library. You can also put these two .exe in the same folder that your project.
the path is a little bit from Arduino IDE and PlatformIO
Arduino is some thing like:
%userprofile%\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-4-b40a506\xtensa-lx106-elf\bin
PlaformIO is:
%userprofile%\.platformio\packages\toolchain-xtensa\xtensa-lx106-elf\bin
Or, you can you put "ar.exe" in the file search, right clic and open File location.
This will generate a folder called "data" with a "certs.ar" inside. them, just upload File System image with LittleFS from Arduino IDE, I recommend, also use Arduino IDE for upload your sketch, I don't know why but PlatformIO doesn't not upload correctly the LittleFS library and can't find the certs. Here the link to my issue to platformio forums:
https://community.platformio.org/t/is-e ... -ide/14327This, look too much, just add "setInsecure" for the easy way.
Let me know if something if bad with the code and the instruction.
