#include <Arduino.h>
#include <ESP8266WebServer.h>
#include <ESP8266mDNS.h>
const char *wifiName = "XXX";
const char *wifiPassword = "YYYY";
ESP8266WebServer server(80);
int ledPin = 1;
void handleRoot()
//digitalWrite(ledPin,LOW);
server.send(200,"text/plain","hello from esp8266");
delay(1000);
//digitalWrite(ledPin,HIGH);
delay(5000);
//pinMode(ledPin,OUTPUT);
Serial.print("Conectando");
WiFi.begin(wifiName,wifiPassword);
/* code */
Serial.print(".");
Serial.println("");
Serial.println("Conectado por WIFI");
Serial.println("Dirección IP: ");
server.on("/", handleRoot);
server.begin();
Serial.println("Servidor HTTP iniciado");
server.handleClient();
the problem that I have here is that if the wifi connections is initiated then the board doesn't send any data over serial but if the wifi connection is not initiated then the data is sent normally. As you noted I've commented the writing to the "ledPin" since it is the same pin where is TX but even by doing that the ESP-01 doesn't send the data over serial with wifi enabled.
I think the wifi is somehow disabling the serial port but I don't know for sure.
Can anyone help me with this?.
Thanks in advance for the help.
