By Piotruchk
#92576 how to change the time of sending to the database currently the data is sent every 7 seconds and I would like to ultimately 15 minutes
Kod:
#include <Wire.h>
#include <OneWire.h>
#include <DallasTemperature.h>
const char *ssid = ""; //nama wifi
const char *password = ""; //password
const char *host = ""; //IP PC
//memasukkan pin
int sensorPinDS18b20 = 4;
//membuat variabel kosong
float suhuC;
OneWire ourWire(sensorPinDS18b20);
DallasTemperature sensors(&ourWire);
delay(1000);
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
sensors.requestTemperatures();
suhuC = sensors.getTempCByIndex(0);
Serial.println(host);
WiFiClient client;
const int httpPort = 80;
if (!client.connect(host, httpPort))
return;
// We now create a URI for the request
String url = "/nodemcu-esp8266-with-DS18B20-Sensor-MySQL-Database/add.php?";
url += "suhu_air=";
url += suhuC;
Serial.println(url);
"Host: " + host + "\r\n" +
"Connection: close\r\n\r\n");
unsigned long timeout = millis();
while (client.available() == 0)
if (millis() - timeout > 5000)
Serial.println(">>> Client Timeout !");
client.stop();
return;
while (client.available())
//Serial.print(line);
if (line.indexOf("sukses gaes") != -1)
Serial.println("Yes, data masuk");
else if (line.indexOf("gagal gaes") != -1)
Serial.println("Maaf, data gagal masuk");
//digitalWrite(alarmPin, HIGH);
//menampilkan hasil pembacaan sensor Suhu DS18b20
Serial.print("Suhu = ");
Serial.print(suhuC);
Serial.print(" ");
Serial.println("C");
delay(1000);
Kod PHP:
<?php
include('conn.php');
$sensor = $_GET['suhu_air'];
$sql = "INSERT INTO tbl_water (suhu_air) VALUES(:suhu_air)";
$stmt = $PDO->prepare($sql);
$stmt->bindParam(':suhu_air', $sensor);
if($stmt->execute()) {
echo "sukses gaes";
}else{
echo "gagal gaes";
