By rvinaso
#94820 Hi friends!! I have been working in a code, that basically extracts the credentials of a wifi network that I previously have stored in Flash Memory of my ESP8266. The problem is that when I use Wifi.begin() fuction it doesn't connect to the network because there are wrong characters in the credentials.I added the code with some comments of where I detected the problem.Thanks a lot!
#include <splash.h>
This sketch trys to Connect to the best AP based on a given list
#include "FS.h"
#include <ArduinoJson.hpp>
#include <ArduinoJson.h>
bool spiffsActive = false;
String json;
int Pin1 = 1;// is connected TX azul
int Pin4 = 3;// is connected RX amarillo
#include <SPI.h> // needed for Arduino versions later than 0018
#include <Ethernet.h>
#include <WiFiManager.h>
#include <WiFiUdp.h>
#include "DHT.h"
#define DHTPIN 2
#define DHTTYPE DHT11
#include <Wire.h>
#include "SSD1306.h"
bool activateWifiManager = false;
int contador;
int listoparaenviar = 0;
const char* ssidjson;
const char* passwordjson;
const char *ssidwifi ;
const char * passwordwifi;
const char* ssidSmartCentral="SmartCentral";
const char* incomingSsidwifi ;
const char* incomingPasswordwifi ;
unsigned int localPort = 8888;
String routerSSID;
String routerKey;
int salvarConfig = 0;
char packetBuffer[UDP_TX_PACKET_MAX_SIZE]; //buffer to hold incoming packet,
//int D0;
int activar = 0;
int salvarSSID = 0;
int salvarPASSWORD = 0;
String state2;
WiFiManager wm;
WiFiUDP Udp;
DHT dht(DHTPIN, DHTTYPE);
SSD1306 display(0x3c, 4, 3); // revisar los pines de comunicacion a lo mejor lo q chiva el json son los pines q se usan para otra cosa
#define flipDisplay true
uint8_t MAC_array[6];
char MAC_char[18];
IPAddress server;
String ipadd;
String paquete = "esperando";
void writeDisplay(String mostrar,int espera)
{display.clear();
display.setFont(ArialMT_Plain_16);
display.drawString(0, 0, mostrar);
display.display();
delay(espera);
void SerializeObject(String wifi_ssid, String pass_wifi)
StaticJsonDocument<300> doc;
doc["SSID"] = wifi_ssid;
doc["PASSWORD"] = pass_wifi;
serializeJson(doc, json);
Serial.println(json);
void DeserializeObject(String desjson)
DeserializationError err = deserializeJson(doc, desjson);
if (err) {writeDisplay("NO JSON",5000);
return;
ssidjson = doc["SSID"];
passwordjson = doc["PASSWORD"];
escribe contenido en un archivo
string state - contenido a escribir en el archivo
string path - archivo que se va a escribir
void writeFile(String state, String path) {
File rFile = SPIFFS.open(path, "w+");
if (!rFile) {
Serial.println("Error abriendo!");
} else {
rFile.println(state);
Serial.println(state);
rFile.close();
void appendFile(String state, String path) {
File rFile = SPIFFS.open(path, "a+");
if (!rFile) {
Serial.println("Error!");
} else {
rFile.close();
el contenido de un archivo
param cadena path - archivo que se va a leer
return string - contenido leído del archivo
String readFile(String path) {
File rFile = SPIFFS.open(path, "r");
if (!rFile) {
Serial.println("Error !");
String content = rFile.readStringUntil('\r');
Serial.print("reading state: ");
Serial.println(content);
rFile.close();
return content;
@desc inicializa el sistema de archivos
void openFS(void) {
if (!SPIFFS.begin()) {
Serial.println("\nError abriendo archivo spiffs");
} else {
Serial.println("\nSuccess iniciando Spiffs!");
void setup()
delay(10);
dht.begin();
display.init();
if (flipDisplay) display.flipScreenVertically();
writeDisplay("STARTING",3000);
Udp.begin(localPort);
WiFi.mode(WIFI_STA);
delay(1000);
// Start filing subsystem
if (SPIFFS.begin()) {
Serial.println("SPIFFS Active");
// Serial.println();
spiffsActive = true;
} else {
//Serial.println("Unable to activate SPIFFS");
delay(2000);
openFS();
state2 = readFile("/config.txt");
DeserializeObject(state2);
delay(1000);
ssidwifi=ssidjson;
passwordwifi=passwordjson;
Serial.println(ssidwifi);////here everything is ok
Serial.println(passwordwifi);
WiFi.begin(ssidwifi, passwordwifi); //
Serial.println(ssidwifi);//////here credentials have wrong characters
writeDisplay(ssidwifi,3000);
writeDisplay(passwordwifi,3000);
writeDisplay("Searching",3000);
////////////////////////////////////////////////////levantar el hotspot si no se conecta
// Serial.println("WiFi not connected!");
writeDisplay("waiting wifi",100);
contador++;
if (contador == 1800) ///se cumple el minuto sin conectarse a la central
{ writeDisplay("No central",5000);
activateWifiManager = true;
//break;
if (activateWifiManager == true) ///activo el hotspot propio
{ bool res;
writeDisplay("Starting AP",3000);
res = wm.autoConnect("SmartSensor", "12345678");
routerSSID = WiFi.SSID().c_str(); //cojo clave y
routerKey = WiFi.psk().c_str(); //password del router
ssidwifi = routerSSID.c_str();
passwordwifi = routerKey.c_str();
SerializeObject(ssidwifi, passwordwifi);
writeFile(json, "/config.txt"); //los guardo
else ///////// se conecta a la central directamente
writeDisplay("central found",3000);
IPAddress broad = WiFi.localIP();
broad[3] = 255;
Udp.beginPacket(broad, 8888);
Udp.write("credentials");
Udp.endPacket();
//////////////esperar las credenciales para conectarse a la red&//////
while(salvarSSID == 0)
writeDisplay("Waiting credentials",100);
int packetSize = Udp.parsePacket();
if (packetSize)
IPAddress remote = Udp.remoteIP();
Udp.read(packetBuffer, UDP_TX_PACKET_MAX_SIZE);
//Serial.print("Contents: ");
String mensaje = packetBuffer;
Serial.println(mensaje);
if (mensaje.substring(0, 4) == "net:")
{String credentials = String (mensaje.substring(4));
DeserializeObject(credentials);
salvarSSID = 1;
writeDisplay("serializing",3000);
SerializeObject(incomingSsidwifi, incomingPasswordwifi);
delay(2000);
ssidwifi=incomingSsidwifi ;
passwordwifi=incomingPasswordwifi;
memset(packetBuffer, 0, sizeof(packetBuffer));
writeDisplay("displaying cred",3000);
delay(2000);
delay(3000);
if(WiFi.status() == WL_CONNECTED)
{writeDisplay("Wifi ok",5000);
//////////////////aqui ya el se conecto al router/////////////////////////////////
broad[3] = 255;
String dir_Mac = WiFi.macAddress(); //cojo la direccion mac
Serial.print("Direccion MAC");
Serial.println(dir_Mac);
WiFi.macAddress(MAC_array);
for (int i = 0; i < sizeof(MAC_array); i++)
{ sprintf(MAC_char, "%s%02x", MAC_char, MAC_array[i]);
Serial.print("MAC CON ARRAY: ");
Serial.println(MAC_char);
writeDisplay("Sending",3000);
Udp.beginPacket(broad, 8888); //direccion de broadcast
//envia un paquete a todos los elementos de la red
// el servidor debe almacenar esta direccion
Udp.write("sentemp:");
Udp.write(MAC_char);
Udp.endPacket();
delay(10);
while (paquete == "esperando")
{ writeDisplay("Waiting",3000);
if (packetSize)
// read the packet into packetBufffer
paquete = packetBuffer;
if (paquete == "sincronizado")
server = Udp.remoteIP();
listoparaenviar = 1;
if (paquete == "esperando")
Udp.endPacket();
delay(10);
writeDisplay("Sincronized",3000);
if(listoparaenviar==1)
{char* buffn="";
char buffer[1024]=" ";
float humedad = dht.readHumidity();
// Read temperature as Celsius
float temp = dht.readTemperature(true);
// Check if any reads failed and exit early (to try again).
if (isnan(humedad) || isnan(temp) ) {
return;
dtostrf(temp,3,2,buffn);
sprintf(buffer,buffn);
Udp.beginPacket(server, 8888);
Udp.write(buffer);
Udp.endPacket();
display.clear();
display.setFont(ArialMT_Plain_24);
display.drawString(0, 0, buffer);
display.display();
delay(10000);
if (WiFi.status() != WL_CONNECTED) ///se cayo la conexion por alguna razon
writeDisplay("LOST CONN",1000);
listoparaenviar=0;
{listoparaenviar=1;
And it is what returns from the Serial Monitor:
reading state: {"SSID":"SmartCentral","PASSWORD":"12345678"}
SmartCentral
12345678
