[SOLVED] load ESPduino firmware, getting boot mode:(1,1)
PostPosted: Fri Jun 05, 2015 11:37 am
by charlie
Hello,
I'm following Tuan's instructions on loading the firmware on a ESP8266 (ESP-01 version) :
https://github.com/tuanpmt/espduino
But when I run esptool.py, I get a connection error. Using miniterm, I see that my ESP8266 is booting up to
ets Jan 8 2013,rst cause:1, boot mode:(1,1)
I have another ESP8266 that boots up to boot mode:(1,0). Someone on the forum said the boot mode should be (1,7).
I'm sure I have D0 pin grounded, which is supposed to tell the ESP8266 to go into firmware load mode. My 3.3V power supply is pretty good, so it shouldn't be a power issue. Any other tips?
Re: [SOLVED] load ESPduino firmware, getting boot mode:(1,1)
PostPosted: Sat Jun 06, 2015 2:17 pm
by AcmeUK
So what was the solution? Recording it here may help someone else.
