So I am not a HW guru like some of you
I few years back, using hc-05 and Arduino, I hacked together an LED strips controller that I could control with my Android phone, basically I use the Bluetooth module (hc-05 http://www.ebay.com/itm/like/2909258454 ... =82&chn=ps) to communicate with the Arduino (serial communication, RX/TX -> TX/RX).
I’ve got a few esp03s so I thought why not replace the hc-05 with the esp03? So over the weekend I wrote some lua scripts that reads stuff (string, like r1:100, g3:200 and etc) from a socket and passes the info to esp03’s uart, and the message from the arduino’s uart is passed back to the socket, nothing fancy.
My test setup is as following:
The esp03 is powered from a 3.3v voltage regulator that is connected to http://www.ebay.com/itm/DC-DC-Buck-Conv ... 3aac74a9e8
The Rx/TX are connected to a 3.3v FTDI, I verified the messages from and to esp in the espexplorer console.
But when I power the esp03 (via same 3.3v regulator, which has a large (1F) in the vin and a smaller capacitor on the vout) from http://www.ebay.com/itm/SUPERNIGHT-12V- ... 2a334f04ba, I get a lot of junk characters in RX/TX readings.
At first I had the esp03’s RX/TX directly connected to the Arduinos TX/RX. Note that, the same setup with the hc-05 works just fine.
Then I added two pull up resistors (tried 1K and 100 Ohm) to both RX/TX, and same results.
Does someone know what is going on?
Thanks a bunch.
/N
