By Chris Carter
#23549 Hey everyone, I'm trying to parse some xml text from timezonedb.com to get the current timezone offset and daylight savings time for my clock. I'm getting 403 forbidden requests whenever I try get requests. Can anyone shed any light on this?
Code: Select allvoid connectToDSTServer() {
  String GETString;
  // attempt to connect, and wait a millisecond:
  IPAddress DSTServerIP = dns;
  int rc = WiFi.hostByName(DSTTimeServer, DSTServerIP);
  Serial.println("Connecting to DST server");
  Serial.println(DSTServerIP);
  DSTclient.connect(DSTServerIP, 80);
  if (DSTclient.connect(DSTServerIP, 80)) {
    // make HTTP GET request to twitter:
    GETString += "GET /?lat=";
    GETString += latitude;
    GETString += "&lng=";
    GETString += longitude;
    GETString += "&key=N9XTPTVFZJFN\r\n";
    Serial.println(GETString);
    DSTclient.print(GETString + " HTTP/1.1\r\n");
    DSTclient.print("Host: api.timezonedb.com\r\n");
    DSTclient.print("Accept: */*\r\n");
    DSTclient.print("User-Agent: Mozilla/4.0 (compatible; esp8266 Lua; Windows NT 5.1)\r\n");
    DSTclient.print("Connection: close\r\n\r\n");
    int i=0;
    while((!DSTclient.available()) && (i<1000)){
      delay(10);
      i++;
void readDSTtime() {
  String currentLine = "";
  bool readingUTCOffset = false;
  String UTCOffset;
  connectToDSTServer();
  Serial.print("DST.connected: ");
  Serial.println(DSTclient.connected());
  Serial.print("DST.available: ");
  Serial.println(DSTclient.available());
  while(DSTclient.connected()) {
    if(DSTclient.available()) {
      // read incoming bytes:
      char inChar = DSTclient.read();
      // add incoming byte to end of line:
      currentLine += inChar;
      // if you get a newline, clear the line:
      if (inChar == '\n') {
      Serial.println(currentLine);
        currentLine = "";
      // if the current line ends with <text>, it will
      // be followed by the tweet:
      if ( currentLine.endsWith("<gmtOffset>")) {
        // tweet is beginning. Clear the tweet string:
        readingUTCOffset = true;
        UTCOffset = "";
      // if you're currently reading the bytes of a tweet,
      // add them to the tweet String:
      if (readingUTCOffset) {
        if (inChar != '<') {
          UTCOffset += inChar;
        else {
          // if you got a "<" character,
          // you've reached the end of the tweet:
          Serial.print("UTC Offset in seconds: ");
          Serial.println(UTCOffset);
          // close the connection to the server:
          DSTclient.stop();
