By Duane J
#24206 Hi! I've been trying to figure out if the esp-12e's LED can be controlled separately from its function as a UART communication indicator light. Right now, when I upload a program or communicate with the serial console, a small blue LED flashes on the 12e. Is it possible to control this LED separately? I've tried all of the GPIOs and can't seem to get it to work. Thanks!
By DannyBoy
#26154 I also have a problem with using the onboard LED on my ESP-12E module.
It does not work with GPIO1 (It works fine with other modules, including ESP-12, but not ESP-12E).
Update:
My ESP-12E has onboard led connected to GPIO2 thru internal 470 Ohm resistor.
