By loyaproject
#25177 Hello,
i try to send data with my esp8266 with UDP protocol.
it say send ok but i receive no data on maxmsp on my other computer.
but i can send data with maxmsp and it work fine.
can anyone help please.
here is my code
Code: Select all#include <SoftwareSerial.h>
SoftwareSerial ESP8266(10, 11);
String NomduReseauWifi = "myssid";
String MotDePasse      = "mypassword";
/*                             INIT                             */
void setup()
  Serial.begin(9600);
  ESP8266.begin(9600);
  initESP8266();
  envoiTcp();
/*                        BOUCLE INFINIE                        */
void loop()
   while(ESP8266.available())
     Serial.println(ESP8266.readString());
/*                Fonction qui initialise l'ESP8266             */
void initESP8266()
  Serial.println("**********************************************************");
  Serial.println("**************** DEBUT DE L'INITIALISATION ***************");
  envoieAuESP8266("AT+RST");
  recoitDuESP8266(2000);
  envoieAuESP8266("AT+CWMODE=3");
  recoitDuESP8266(5000);
  envoieAuESP8266("AT+CWJAP=\""+ NomduReseauWifi + "\",\"" + MotDePasse +"\"");
  recoitDuESP8266(10000);
  envoieAuESP8266("AT+CIFSR");
  recoitDuESP8266(1000);
  envoieAuESP8266("AT+CIPMUX=1");
  envoieAuESP8266("AT+CIPSERVER=1,80");
  Serial.println("***************** INITIALISATION TERMINEE ****************");
  Serial.println("");
void envoiTcp(){
 envoieAuESP8266("AT+CIPSTART=4,\"UDP\",\"192.168.0.13\",8000");
 envoieAuESP8266("AT+CIPSEND=4,18");
 envoieAuESP8266("GET /THEAP/1.0");
 envoieAuESP8266("");
/*        Fonction qui envoie une commande à l'ESP8266          */
void envoieAuESP8266(String commande)
  ESP8266.println(commande);
  //Serial.println(commande.length());
/*Fonction qui lit et affiche les messages envoyés par l'ESP8266*/
void recoitDuESP8266(const int timeout)
  String reponse = "";
  long int time = millis();
  while( (time+timeout) > millis())
      char c = ESP8266.read();
      reponse+=c;
  Serial.print(reponse);
By GigAHerZ
#25272
AcmeUK wrote:Hi loyaproject
Is your code correct? You have
Whereas Espressif give this example
AT+CIPSTART=4,"UDP","192.168.101.110",8080
He's escaping double-quote. It's correct, so no fault at there at least.
By AcmeUK
#25278
OK.
So loyaproject, it looks to me that you are using port 8000 for UDP communication. Just a couple of thoughts:-
1, Is your UDP receiver listening on port 8000?
2, Is there another service on your UDP receiver that has 'grabbed' port 8000?
I have UDP send working fine between ESP8266 and a Python script using port 5000, but I am not using AT commands.
I also have a NTP script running which uses UDP, but again not using AT commands.
