Page 1 of 4
Send data from one module (AP) to another (station connected
PostPosted: Thu Aug 13, 2015 3:46 am
by AlexPilk
I want to have one module as an access point and the second module as a station connected to the access point. The station should read the webpage on the access point's server.
Say my access point code is this:
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#include <EEPROM.h>
const char *ssid = "ESPapnew";
const char *password = "thereisnospoon";
ESP8266WebServer server(80);
void handleRoot() {
  server.send(200, "text/html", "Hello, world!");
  delay(1000);
  WiFi.softAP(ssid, password);
  server.on("/", handleRoot);
  server.begin();
  server.handleClient();
How should the code look like for the second module set up as the station for it to read that webpage and store "Hello world!" in a string variable for future use? I saw some examples with functions like wifi.send(), but I still have no idea how to implement it. It can also be set up like this: the server on the access point sends data to the server on the station when an event occurs (no matter what, a button is pressed, a url on the server is visited) and the station stores it in a variable. Thanks!
Re: Send data from one module (AP) to another (station conne
PostPosted: Thu Aug 13, 2015 8:33 am
by martinayotte
Simply use the example under libraries/ESP8266WiFi/examples/WiFiClient/WiFiClient.ino and change the connect to point to your AP.
PostPosted: Thu Aug 13, 2015 8:43 am
by kolban
Howdy Alex,
Assume ESP_AP is the ESP being used as an access point.
Assume ESP_STA is the ESP being used as a station connected to ESP_AP.
I hear you say that you are running a WebServer on ESP_AP and that ESP_STA wants to get data from ESP_AP. Are you sure you need to run a WebServer on ESP_AP? ESP_STA can make a TCP request directly to ESP_AP to request data without going anywhere near WebServer technology. I just want to make sure you aren't going through the WebServer story because you aren't aware of that? Perhaps if you describe the overall story that might assist?
Neil
PostPosted: Fri Aug 14, 2015 3:48 am
by AlexPilk
kolban wrote:Howdy Alex,
Neil
Hi! Yes, it needs to have a server, it's another part of the project. What I want is ESP_AP sending data to ESP_STA when a button connected to ESP_AP is pressed. I checked out the wifi client sketch, but it looks like it works the other way around, the station sends the request. So is it possible to set up ESP_AP as a client sending the requests to ESP_STA? If not, maybe it's possible to set up ESP_AP as an access point and a station connected to the second module at the same time? Thanks!
